Just spent a good few hours reading over and over this thread, the more I was reading the more I was getting gd up for my car to finish, okay for the last year and half I've been building my full house rb26 in my r32 Gtr
Specs are-
Bottom end-
JE Forged pistons
Manley con rods
Arp head/main studs
Cometic metal head gasket
Tomei oversized oil pump
Jun oil collar attached to my crank
Black full honed, blue printed etc
Acl bearings
Tomei oil restrictor
Ross harmonic balancer
Racepace extended 9l sump
Head-
Tomei 270deg 10.80mm lift Procams
Tomei type c valve springs
Tomei solid lifters
Tomei valve guides
Nitto head oil return
N1 water pump
Nismo thermostat/housing
Head all freshened up and machined to use aftermarket gear
Fuel setup -
Bosch 2000cc injectors
Pro flow twin entry fuel rail
5l surge tank
2x bosch 044 fuel pumps with a sard 280 internal pump
Turbo setup-
Precision 6466 DBB t4 twin scroll .84 purchased from gas motor sports
Custom crg twin scroll exhaust manifold
Precision 46mm external waste gate
Gearbox-
5 speed os giken gearset
Jim berry full Monty clutch
Have heaps of other bits and peices that I havnt mentioned but engine should be Goinf back in next week and keen to see what it makes on the dyno after run in tune, car will be running e85 all the time, will keep you guys updated but hoping for 500+kW
Edited by gdzlar1
  • Like 1
I've already purchased it man and got it right beside me lol, I honestly got .84 because either way the 6466 makes power but I would like the response aswell at the same
Time
Sorry forgot to mention it's got the t4 housing aswell
Exact same 6466 I put on my 25/30. Mines not really overly laggy, I couldn't imagine what the larger rear would be like though
That's insane pj 630kw is serious power lol, Anthony at mattouk said I should be able to grab anywhere from 500-550kw with this setup so let's see how we go, I was told by joe at gas motorsports this turbos wil do
It with ease I was Goinf the 1.00 ar but I want some response as it's a t4 so .84 was good for me I think
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
