Just spent a good few hours reading over and over this thread, the more I was reading the more I was getting gd up for my car to finish, okay for the last year and half I've been building my full house rb26 in my r32 Gtr
Specs are-
Bottom end-
JE Forged pistons
Manley con rods
Arp head/main studs
Cometic metal head gasket
Tomei oversized oil pump
Jun oil collar attached to my crank
Black full honed, blue printed etc
Acl bearings
Tomei oil restrictor
Ross harmonic balancer
Racepace extended 9l sump
Head-
Tomei 270deg 10.80mm lift Procams
Tomei type c valve springs
Tomei solid lifters
Tomei valve guides
Nitto head oil return
N1 water pump
Nismo thermostat/housing
Head all freshened up and machined to use aftermarket gear
Fuel setup -
Bosch 2000cc injectors
Pro flow twin entry fuel rail
5l surge tank
2x bosch 044 fuel pumps with a sard 280 internal pump
Turbo setup-
Precision 6466 DBB t4 twin scroll .84 purchased from gas motor sports
Custom crg twin scroll exhaust manifold
Precision 46mm external waste gate
Gearbox-
5 speed os giken gearset
Jim berry full Monty clutch
Have heaps of other bits and peices that I havnt mentioned but engine should be Goinf back in next week and keen to see what it makes on the dyno after run in tune, car will be running e85 all the time, will keep you guys updated but hoping for 500+kW
Edited by gdzlar1
  • Like 1
I've already purchased it man and got it right beside me lol, I honestly got .84 because either way the 6466 makes power but I would like the response aswell at the same
Time
Sorry forgot to mention it's got the t4 housing aswell
Exact same 6466 I put on my 25/30. Mines not really overly laggy, I couldn't imagine what the larger rear would be like though
That's insane pj 630kw is serious power lol, Anthony at mattouk said I should be able to grab anywhere from 500-550kw with this setup so let's see how we go, I was told by joe at gas motorsports this turbos wil do
It with ease I was Goinf the 1.00 ar but I want some response as it's a t4 so .84 was good for me I think
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
