gimmick?? like the throttle mod that is available for V35s
One and the same :down:
They do "work" but in the end all we want is to remove the low rpm restriction which is implemented by the ecu and is, obviously, dependent on rpm which makes these throttle "controllers" largely redundant.... unless you want a not-so-sensitive accelerator pedal for freeway travel of course.
Edited by iamhe77
after a time without getting to the forum this is something I found in a mag...
Would be much like the other I would think.
It is the ECU that limits power by rpm, not so much via pedal position when under 3000rpm.
Reflash or standalone ECU is pretty much the only way if after low rpm power for the VQ25det...
... or change to a cable throttle and all the extras like Scotty has
You are right Iain but how long does it take for your foot to reach full throttle? They work well at the job they do, and you will accelerate faster in sport mode, but the throttle gets too touchy for everyday travel. In eco mode the throttle is less sensitive and gives you better fuel economy by not opening the throttle more than needed.
I found the number 3 eco mode to be the best for cruising but that is because of the massive midrange of my engine around 3-4k revs, where the stock throttle map was way too touchy. Like I said, they have their uses, just dont expect them to fix anything other than the acceleration curve in relation to the pedal.
It all comes down to the type of road you are driving on and how constant you can keep the speed.
Just near the end of my Easter road tour around Vic and a few thousand k's later I can see how the car behaves on different road conditions and how the car responds.
Using cruise control on the Hwy set at 2km/h above legal limit (damn VIC police) and got between 10.4 - 10.1L/100km per tank. During the prolonged Hwy cruising I could see the exhaust gas temp rise to between 500 - 600c at around 2000rpm. Which indicates the ECU leans out the motor at this sort of light throttle input and road speed.
Once back in the hills the car would average 12.3 - 12.8L/100km and the exhaust temp would be lower 400 - 500c until on the throttle and would peak at around 700c but mostly around the 500c mark.
But I love this car driving on windy roads.
Cheers
Andy
  • 3 weeks later...
Bit of a grave dig, but has anyone installed the Works Bell paddle shift yet? Does the V35 kit work?
Chris.
On my list(it's a long list)......cannot see why it would not work. Your talking about this one?
http://www.tunersgroup.com/Online_Store/Wo...mn_Shifter.html
Yep that's the one.
I just got off the phone to Adam from tunersgroup.com (really helpful guy) and placed my order for the above kit.
He explained that the M35 Stagea kit only works with aftermarket steering wheels but the paddles move with the wheel.
The above 350Z / V35 kit is fixed to the column and works with the standard airbag steering wheel.
I will post pics of the install and let you guys know how it all goes.
Chris. :)
Will be interesting to see how you go.
HERE is an install on a Z33 if you haven't already seen it.
Have you done the quick wire cross to change the +/- around on the gear shifter? (ie pull back to change up through the gears 1,2,3,4,5 and push forward to change down through the gears 5,4,3,2,1)
If you have, will this make a difference to the paddles? Would suck pretty bad if it did.
Yep that's the one.
Chris. :D
good stuff chris.....look forward to seeing this.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
