  • Replies 40
Posted Images
nice, did they find what was causing the attesa to fail?
Those trailers are sweet, we have one of them.
Yes it is with a new Racepace motor, new brakes and Attessa system all good, now.
Chris from Racepace was the man. One dodgy wheel sensor and some extra wiring disconnected. I am real happy with the trailer. Great engineering and quality. Manufactured and delivered within 2 weeks also.
Bar the Whites Gallardo in its very very latest spec, I think yours is the hottest looking tarmac rally car to be found... massive shame the spotless Peter Moore 34 N1 no longer lives... back a few years ago when they were both running they were a awesome pair.
Those Nevco trailers are great hey, so easy to use.
I don't think it's the hottest but thanks for your comments.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
