I went the Strathfield yesterday to look at their sale. I was almost talked into buying this combo:
Sony 800w 12" sub in a carpetted Sony box (heavy)
Sony Xm222 2 channel amp
Power and trigger cabling
RCA cables
$300
I dont know anything about car audio so I thought I would ask on here first. Im not really that worried about max power output, i would just like to hear some bass that doesnt vibrate my parcel shelf.
Thanks
https://www.sau.com.au/forums/topic/31495-is-this-a-good-deal/
its an alright deal..but for that budget i'd go 2nd hand and get some decent stuff for the same price. www.webaudiodirect.com for a cheap nice sub.
jaycar for cabling.
and a small 2nd hand amp to make up $300.
reason being, that amp is very small and used for speakers mostly.
not to mention the 222W model doesnt have any crossovers at all which is very rare for an amp..
cross over basicly is to cut curtain freq's out there should be one on your amp.
its used on the sub so it only recieve low freqs etc
some1 could do a better job of explainin but anyway no ones replyed !
if ur lookin for some splits to buy let me no i have clarions top of the range splits for sale $375 or nearest offer that will be have to be sold ASAP they retail for $550~
Yes, the crossover is a frequency filter.
I'm not the biggest fan of Sony stuff but for the price that looks quite nice. Just be careful to make sure you have quality cables. :P
Remember the old analogy; Top Fuelers don't run on quarter inch fuel lines. Amps don't pump power without the appropriate sized cables.
Ok so i got paid yesterday so i went and got the said equipment. Its pretty damn sweet. I had already wired up the Subwoofer outs to the boot last week because i had the dash off so all I had to do was wire the power up today.
So now with a JVC headunit powering 2 x 6inch clarions in the front and 2 x 6inch clarions in the back and a sony XM222 amp bridged powering the 12" 800w xplod sub in the boot it sounds quite nice.
Ive turned the rear clarions down a bit just enough to be audible to fill out the sound a little.
I turned the amps Low Pass Filter to "ON" but since im using the subwoofer outputs on the headunit should I leave the LPF off or on?
For cabling i have some AEPro RCA cables from the headunit to the boot, for power i have some 8 gauge stuff directly from the battery positive and negative terminals.
For speaker cable im using some 168/0.12mm or something from dick smith. Wasn't the thickest but wasnt the thinnest either. Only needed 1 meter so cant be too bad.
For terminals im using some from dick smith again. Should i solder the terminals as well as squashing them?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
