Yup, agree. I too prefer the nismo. For my car it's a bit overkill anyways. I couldn't see anything when I looked down a legalis, where as the nismo defiantly had the step down in it. Just goes to show, if you want outright and performance, go and see a fabricator like Scotty, then you know what your getting in regards to size. The GTR guys found this on their jap systems too!
The twin Nismo is 70mm internal to the muffler, where as the Fujitsubo has twin 70mm in the rear muffler. Theoretically the Nismo should be quieter then. I wonder how much it will restrict flow...
  • Like 1
Hey guys just did the brake cut mod today (simple and cheap) and after having the stag for around 8mths the need for more power is starting to arrive. I think exhaust is next but I love the fact my m35 is so quiet but spanks most cars with no fuss so I'm thinking dump pipe but the rest of exhaust standard? Will this give a good increase in power or would a full exhaust be way better? Money is also a bit of an issue as I don't think the missus is fully buying the " it's for better fuel economy line". Any advise would be aprechiated.
If you were looking at doing one part of the exhaust the dump would be it. They have an extra Cat in them that really just doesn't flow. But really to take full advantage you would want to put a full system thru.
There are some quite exhaust options, for example the single outlet nismo that I have. It's not much louder then stock.
I did a 3" dump pipe on a standard exhaust, and it does make a difference; the stock dump is massively restrictive.
I'd advise a dump & front pipe with hiflow cat in 3", then reduce to 2.5 and into the stock system, if you need to keep it under the radar with the missus.
There would be a good gain in kw and torque, but virtually no change in exhaust note.
  • 3 months later...
Has anyone ever had a resonator installed on their M35? If so, how did you go about it and what were the results?
I've got a Kakimoto R catback with custom dump pipe and front pipes but it's just too loud.
I'd like to add a resonator but was told there isn't enough straight sections in the system to fit one.
Any ideas?
Cheers
A resonator? What you want is a Helmholtz chamber, like the Nismo/Fujitsubo cat backs run. You won't find many exhaust shops that know what they are...
Easiest way is to fit a Varex muffler on the end, or run an active exhaust valve with a bypass muffler.
Any ideas?
Cheers
Do you still have a Cat in your set up?
Just asking as I have picked up a Kakimoto N1 and am wondering how loud this is going to be...
As Scotty mentioned Helmholtz chambers feature on a few M35 Jap shelf exausts, fujitsubo one looks like this.
Maybe see if you can get someone to fab up one for you?
Thanks again Scott for that. I did consider the Helmholtz chamber but thought it would cost too much to fabricate a custom one.
I might ask around more.
Dmyze - Yep I have a cat which is connected to my front pipe. The Kakimoto R is pretty damn loud but it's the cabin drone which kills it for me.
It's even more of an issue since I have a 2 year old plus another on the way.... I need it as quiet as possible.
Thanks for the feedback guys.
Does a new dump and front pipe do much for exhaust noise?? Bit curious because i wouldnt consider my kaki cat back loud or droney at all really..
If you had a de-cat front pipe it would make a huge difference. both hte cat and front pipe will have cats inside them standard.
The Kakimoto N1 is loud as f**k lol, Excuse my french, i have one on my car atm. The drone on the inside of the car is also loud tho it gives a good idle tone. I can post a video for sound/to see what it looks like if ya like?
Damn, I've heard the one from the Russian guy Leki on YouTube, if you wanna put up a clip that would be awesome, cheers man.
The girlfriend is gunna love this I can tell, lol :/
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
