Hey all! Selling a few parts off my smashed skyline. It was a r33 gts-t, series 1, 4 door (automatic). I haven't got any pictures as of yet but if pictures are required feel free to ask. Everything is in great working condition. If for some reason a part doesn't work I will offer a full refund. Okay here's the list:
  • Left and Right gas struts for boot $15
  • Series 1 Ignition module $20
  • Power Steer Fluid resevoir cap $5
  • AAC Valve Assembly $30
  • Rear wiper arm with wiper blade $10
  • 6 Factory Coil Packs $100
  • Rb25 AFM (series 1 green label) $25
  • Throttle Body $25
  • TPS (Auto) $25
  • 2 Stock bov's $20 each
  • Crank angle sensor $30
  • Coil pack loom $25
  • 2 Main Auto Ecu's $30 each
  • Stock plenum $50
  • Key ignition surround $2
  • Coin holder for dash $2
  • Center air vents $5
  • Interior clock assembly $5
  • Front and rear passenger door scuff plates $5 each
  • Interior rear view mirror assembly $10
  • Hose from AAC valve to crossover pipe $5
  • Auto ECU (small one on drivers side) $25
  • Boot lock assembly $10
  • Interior passenger sun visor with mirror $10
  • Interior plastic mould cover for main ecu $5
  • S13 clear indicators for front bumper. Brand new never been used. These fit perfectly in my aftermarket front bumper bar. I think it was a 'type 4' bumper from vivagarage.com $30
  • Approximately half a litre of castrol transmax Z. I really don't wanna go throwing this stuff out as its so damn expensive. The best fluid you can get for the auto transmission and retails for about $80/4 litres. Less than 6 months old. $5
  • Exide Endurance battery (310 CCA) just under 2 years old $15
  • Metal elbow pipe from turbo to intercooler piping $5
  • Snorkel bit from stock air box $5
  • Pod enclosure for highmount turbo setup $25
  • HKB aftermarket steering wheel boss kit $15
  • Complete Boot fuse box assembly $20
  • Nissan coilpack cover twin cam 24 valve 2500 $20
  • eyelids for series 1 headlights (black) $10
Feel free to give me a call on 0433373183 rather than sending a PM as I only check my inbox once a day.
  • Replies 45
  • Throttle Body $25
  • TPS (Auto) $25
  • Stock plenum $50
TPS (auto): sold!
Series 1 ignition module: sold!
AAC Valve assembly: sold!
Crank angle sensor: sold!
Coilpack loom: sold!
Nissan coilpack cover: sold!
hay mate chasing the drivers door plastic with the electronics on it ne chance you still have that????
I have the switch surround and switches if he cant help, both out of a series 1
Sorry man but the drivers door was mashed up pretty good. nothing was intact
TPS (auto): sold!
Pod enclosure: sold!
Snorkel from stock airbox: sold!
Just thought I'd add that the steering wheel boss kit I have for sale is actually for hicas as someone on the forums pointed out to me. I also have a few other things that I'm selling as well
  • Climate control unit $10 (i honestly couldn't say if this still works or not. The unit is still intact apart from the clip on the left side which is snapped off but isn't a big thing. Obviously, if it doesn't work I won't charge for it.)
  • TPS (Auto) $20
  • Hicas ECU $15
  • Stock Fuel Pump assembly $20 (was only replaced to make way for a tomei fuel pump)
  • Stock gear knob $10 (manual)
All the other items listed are still for sale.
  • Throttle Body $25
  • TPS (Auto) $25
  • Stock plenum $50
Stock plenum: Sold!
Main auto ecu: Sold! (I still have another one available)
I also have a bonnet lining for sale as well with all the clips. There are a few cuts on the lining due to being involved in an accident but is still usable: $5
If pictures are required feel free to ask.
  • 3 weeks later...
  • 3 weeks later...
still got the stock bov??? need one pls
yea man I still have 2 stock bov's. $20 each. your welcome to come around this arvo if you wish. my number is 0433 373 183
hey mate you got the 90 degree rocker cover fitting
Nah sorry I don't
  • 4 weeks later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
