I would take anything that comes from Fudzilla with a heavy grain of salt. It's like Woman's Day of the PC world.
I'm honestly not convinced these will be viable even if it's true.
Given the price of a 60GB SSD, you could run the O/S off that and then just jab 4TB (1TB 7200rpm drives) into a RAID array and it wouldn't be far off a WD Velo and you'd have a nice amount of space to go with it all and a O/S that would be faster due to the SSD.
Given whats been released in the US the past couple of weeks - SSD prices in a couple of months should start getting closer to reasonable.
A 60GB SSD + a raid array of 7200
or
300GB Raptor + whatever
First one will be much more responsive to use :P
or
First one will be much more responsive to use :laugh:
Only one will lose ~20% of it's perfomance within 6 months.
Oh now now now... that is wrong and you know it. :woot:
A TRIM enabled drive will never degrade.
Even if you dont have a TRIM drive there are ways to clean it up back to 100% working efficency very easily :D
So till SSD then all the way?
On Toms hardware a lot of the testing showed not a huge amount of difference between the raptor and the Caviar black FASS 2TB edition. makes ya wonder, put 2x2TBs in raid format and see if there is much of a comparison at all, price would be pretty good and you would score 4TB compared to 600GB
I have always wanted a raptor though :-)
Of course SSD's are the way - get one with TRIM and you are home free.
Just get a 60/80gb SSD and run the games/OS off that, it'll load faster than the stupid windows sounds play :thumbsup:
If you want mass storage + speed in a network style setup where you are sending large files just mash half a dozen 1.5TB drives together in RAID5.
Don't use onboard though for that much, get a proper hardware raid and it'll be stinking fast for 7200rpm drives.
I can't see a market anymore for Raptors anymore now that you can get SSD's.
They are to expensive on a $$/GB range compared to 7200rpm drives.
They are slower when compared to a SSD
They are just the odd man out now IMO.
Money saved from buying a SSD + RAID 7200s would work out cheaper overall than Raptors + Raptors.
And it would be faster still than Raptors + RAID 7200s. You'd have slightly less space with the SSD route but who cares? Space is unimportant.
I never said to put em on a HDD.
The idea is get a 60GB (ideally 120GB), and then the HDD's are storage.
You'll have near instant load times... with the Velo's you'll still have load times etc.
Not convinced. I have a Raid 5 array of 4xWD 640GB 7200RPM drives (WD6400AAKS with 2x320gb platters, the most efficient 7200rpm drives.) For a grand total of $400. The boot/swapdisk partitions are striped across the inside of the platter, with larger storage areas towards the outside.
The way i see it, each of those have a 3Gbps throughput, which gives me a theoretical max of 12Gbps. Not that I'd ever see it IRL.
This was before SSD's got cheap. Waiting for PCI-E RAM adaptors to become available at normal prices so I can move the swapfiles onto 8GB of RAM.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
