Hey guys.
Just got myself a sound system, JL splits sub amps and pioneer heady, and would like to install it myself. With some help from a mate. Who knows what they are doing :)
I live in the Forrestfield area, though I can travel. Will supply drinks and feed on the day/s of install and will pay cash for your expertise.
0433190501 or sling me a PM.
Unfortunately I work pretty much every saturday so sundays will probably be the only day available to work in it, unless said audio guru also has strange work hours.
Cheers guys
Karl
https://www.sau.com.au/forums/topic/315577-audio-install/
Would have volunteered to help myself, but splits annoy the hell out of me lol, vowed to never do that shit again.
None of that stuff is very hard man, it's a straight wire-in job. The hardest thing is finding where to thread the amp cables through the firewall. If you can find a grommet then it is real easy stuff
https://www.sau.com.au/forums/topic/315577-audio-install/#findComment-5167630
Sounds good bro, hit us up sometime with what time is best for you for sunday? Will have a few beers layin round for ya and sumthin to stuff in ya belly. Can chuck some cash next week as well.
(thinkin might take more than one afternoon)
https://www.sau.com.au/forums/topic/315577-audio-install/#findComment-5167816
Hey Kama, you drive a four door 33 with lots of green on it? And green alloys?
If so I see ya at a cruise a while back :)
Yeah bro, the more help the better, also, your living at High Wycombe is fair handy :)
https://www.sau.com.au/forums/topic/315577-audio-install/#findComment-5167932
No way it will take more than one afternoon to do man, i did my install in a bit over two hours; including sub, two amps, rear 6.5" speakers, and front splits. Did it quite well as well if i do say so myself, nice and tidy.
https://www.sau.com.au/forums/topic/315577-audio-install/#findComment-5167990
I can't do Sunday bro, got work 'til 5. Give Ben (Kama) a holla, he's a heck of a lot closer to you too.
Gimme a buzz if ya desperately can't find anyone. 0424438501
Edited by turbo x-trail
https://www.sau.com.au/forums/topic/315577-audio-install/#findComment-5168025
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
