for R32 skyline
front Tanabe shock with 5zingen springs NO caster TOPS will have to use your std tops to use em
pair headlights 2 diff types of projectors, one has repair job :thumbsup: $30
STD rear suspension no tops $free
For S13
front brakes ca18 non turbo calipers may have disks/pads $Free
clutch fan $free
RB20 parts
coil cover painted ripple red $10
SR20 parts
pulsar SSS turbo import head fwd setup
high port larger silvia valves comes with all cams lifters ect and cover $40
LCA with stubs $10 each
P/S pump and tank $10
random I/C steel pipes $5 each
FOR RX7 s4
Rx7 series 4 turbo flywheel/counterweight and std clutch
approx 60% meat left no hot spots $40
lowered RX7 king springs front $30
series4 import dash cluster $20 80k k's
std shocks rear $10
import orange indicators $10
battery box $10
suzuki 700cc top mount $10
front FC lower lip stick on(MISSING ONE SIDE) $FREE
std white rear S4 bar $FREE
turbo and nonturbo AFM S4 $10
standard Rx7 rims/tyres 80%+ tread $100
ECU's
R33 gtr has a R3 code on the back $20
bug eye wrx Sti import $20
Price and price conditions: beside each part
Pictures: more on request
Contact Details: 0415494235 or [email protected]
Delivery & Conditions of Delivery: PICK UP ONLY
https://www.sau.com.au/forums/topic/315637-shed-cleanout-r32-s13-fc-some-free/
for R32 skyline
For S13
clutch fan $free
RB20 parts
SR20 parts
FOR RX7 s4
std shocks rear $10
battery box $10
ECU's
Interested in the parts i put in bold above? have you got pics? is this for a red top SR20 out of a Silvia?
the head is of a FWD SSS pulsar
CAS location is out the rear of the head for a FWD car
valves lifters rockers maybe intake cam should be the same as redtop but is you wanted to use the head on a RWD you would need to recess the firewall and get a FWD CAS
unless anyone knows differently?
HEADLIGHTS SOLD
Edited by luker
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
