I have managed to get a date of 16th of May. This is a Sunday and will be held in the afternoon. I asume after 12pm.
Private Performance Driving Course
The performance driving course is an opportunity to bring your own vehicles to the skid pan. The four hour session begins with a driver safety briefing and half a hour on performance driving techniques.
After the classroom you will head onto the skid pan where the instructor will go in car for a couple of runs and teach you to drive your particular vehicle under performance conditions.
Cost 8-10 people $825.00
11-16 people $1,110.00
I am allowing up to 16 People, this makes it cheaper for everyone, but depending on how many people are keen on coming will depend on what we all pay. At this stage priority placement will be only given to R32's. If there are spots available later on then I will be opening up entry to other skyline models. Bubba your an exception due to supporting the club and purchasing stickers so if you would like to come no problem.
I will update this List as interest sparks.
1. Dan (bangn)
2. Greg (Gdekwant) SAU
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
Please only say your coming if it is a definate. Due to not being able to book this in until I have full payment and numbers for the event I will need to have this list done this time next week (14th April) to ensure we dont loose our spot, after the 14th, I will be asking for payment for booking the event from those who are keen on coming.
This keep it fair for everyone and ensures nobody misses out because of last minute drop outs
Cheers
Dan
Edited by BANGN
https://www.sau.com.au/forums/topic/315765-r32-skyline-club-rac-day/
18 is probably more than pushing it :)
lol 18psi wiiiikkkid :thanks:
I was running 16 on mine and two weeks later i was pickin parts of the blades out of the zorst,so im guessin that gtr turbs r diff..
Oh yeh hope to b in on this for first club event if am back from kal in time :P
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
