haha thanks heaps Jeff...ye that was me who bought that one. Ive got a stock cat and an airbox. ill put that in soon. Ill try and go to cambelltown too. Do they give you an option? also do you think my fuel pump will get done..its an external one and quite whiny?
Cheers,
Anton
lucky you found one, just remember that the gtst muffler will be quieter! (will need some cutting and rewelding to make it fit though, no biggie)
if you havent already, these mob do great prices on shipping things over (www.transdirect.com.au)
I went to granville so not sure how strict the campbelltown one is but its up to you where you take it
Edited by jeff
went to the one in penrith. to clear the defects was another thing i only had to choices the mechanics in cambelltown or granville i think it was. went to cambelltown as ive heard stories about the other mob being real pricks
Yea the Campbeltown is not too bad.
  • 4 weeks later...
wtf :S is that even possible?
yep sure is
public can complain about the noise, enough complaints results to a notice being sent out to you.
or a cop can note your rego down and send one out.
sucks but thats life nowadays
that sucks, so any asshair off the street can ring up and complain about a car and force the owner to get this test done, just cos they think its noisy? its basically a bill for at least $60 and a lot of fking around
yes
i think thats how i got mine a while back. i leave for work early in the morning (7am) and while warming the car up, it wouldve certainly woken up a few people in our building and next door's from the rumbling and moan of the rb26
imagine getting that every weekday
This is how I was given one.
You can actually find out where the complaint came from by calling the DECC officer on your notice....
And I personally went to campbelltown. Very fair.
Still a massive pain in the backside though!!
I was also given a DECC notice for exhaust loudness and emissions test but no defect when I was pulled over at 7am driving to work :bunny:
I am changing my exhaust back to stock and have already changed the pod back to the original box.
Sorry to hijack but I have a few questions as well and though i would post it in here.
My questions are:
- Do I need a snorkel fitted as well?
- Do I need to remove the front mount intercooler and put the stock sidemount on?
- Do I need to remove my Apexi AVCR solenoid?
- Do they check other things on the car such as ride height of the car etc?
- I'm thinking of going to the inspection place at Rosebay in North Sydney, has anyone been there? What are the people there like?
Thanks guys
- Yep
- Yep
- Yep, i would
- just the exhaust noise level (must be under 90db at 4800rpm) and emissions gear (charcoal canister, stock cat, stock bov, stock smic/piping, stock airbox/snorkel)
- I went to the campbelltown one, they seemed pretty good
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
