yup.. :)
Its white with gtr body kit. (R33 gtst)
when do you wanna go on another cruise ???
(Thanks GTR CAM) :)
what are your settings ?:)
not all of them just the basics like duty,nepoint,bst,scramble,learn gear ?
cheers :D
Mate,
Mine wasn't plumbed correctly so it has been useless since I got the car, have been driving around on about 7-8psi...
Car is now in getting a MOTEC M800, so I'll let you know what settings I'll be using when it's tuned properly...
Cam
https://www.sau.com.au/forums/topic/31632-avc-r-help/#findComment-641091
ok,
have you got it turned off ? or on setting (a) , (B) ?
cause when we put it on settings a or b it misfires ?
so we left it off and it works fine at 7 psi, has this got to do with the setup ?
Sounds like you have a problem similar to mine, although mine wasn't missing as such... Maybe yours just isn't hooked up properly either?
Who did your installation, or was it a DIY jobbie?
Cam
https://www.sau.com.au/forums/topic/31632-avc-r-help/#findComment-641387
we addjust the boost higher and it doesnt go over 10psi on boost guage,
we turned the boost down to .40 and the duty to 70 and it went to 14 psi but it was going now were due to the tubo overspinning i think ?
its weird can use people out their who are useing an avcr on their skyline give the their bst/dty settings :P the other settings are all default if they have to be changed please let us know.
Thanks,
Cameron
https://www.sau.com.au/forums/topic/31632-avc-r-help/#findComment-641617
Ok turn the thing 'Off'
Now go for a drive and see what boost its running. Using my car as an example my car will run 0.6bar (14.5psi=1 bar)
Now if i want to run say 0.8bar, which is not much of a step then i dont need to run a lot of duty cycle, around 30 from memory.
If i wanted to run 1.2 bar then i need to run much higher duty cycle to get that sort of boost increase. The bigger the difference between std boost and your setting the harder it will be for the AVC-R to hold stable boost.
Duty cycle is controlling the opening of the solenoid valve. When the solenoid valve is open the wastegate does not see the actual inlet manifold pressure as its being bled off thru the open valve.
So by increasing the duty cycle you are actually ensuring the valve is open longer, which means more air is bled off fooling the wastegate to stay open as the required pressure has not been achieved to overcome the wasteate's spring.
If you want to run 1.0bar then id suggest setting it to 0.95bar (i found it helps stop overshooting during setup-ceramic wheels and all) and having the duty cylce around 45. If its holding boost fine then tweak it up to 1.0bar, and see if its stable, if not then bump up or down depending on whether it is undershooting or overshooting, the duty cycle a little bit at a time.
Once the thing is holding stable boost it will begin to self learn when coming onto boost on full throttle.
Have a read of the manual, it is pretty easy to set up once you know what the parameters mean. Soem links that give you a rough grounding on setup can be found here Here and Here
https://www.sau.com.au/forums/topic/31632-avc-r-help/#findComment-641643
To answer those questions you need to know how the AVC-R has been wired up. If you are monitoring injector duty cycle, then i think you will find that you are unable to use gear specific boost.
Scramble boost has to be wired up to a separately purchased button, and changing the ne point you are actually changing the rpm when the solenoid valve will start to pulse open/closed. The fact that it will remain closed up to a cerain rpm ensures there is no pressure being seen by the wastegate, so no wastegate creep. I found with the stock turbo it was pretty hard to sense by seats of the pants, but observing the rpm at which duty cycle starts to register gives you an idea of when it begines to play tricks on the wastegate.
Any help???
https://www.sau.com.au/forums/topic/31632-avc-r-help/#findComment-642501
yer,
last night we were playing with it an we tryed your boost settings, (0.95bst - 40%dty)
and it changed the boost to 0.73 so we uped the duty in till we go 1.01bst, the we turned the boost down because we thought the turbo was over spinning we ran 0.85bst and it was on about 12 - 13 psi but the car felt like its going no were, and it looses a great amount of power in 3rd an 4th gear when after 4500rpm ? although the boost guage is saying 12psi ?
what can be done ?
Thanks,
https://www.sau.com.au/forums/topic/31632-avc-r-help/#findComment-642513
yer,
what can be done ?
Thanks,
Sorry maybe i didnt explain myself properly.
It sounds as though your happy running 0.85bar, so ill work with that.
Set the boost to 0.85 bar, and your duty cycle to about 30.
You shouldnt be relying on the duty to get the boost pressure your after. Firstly you should have the boost setting set at the level you want, then tweak the duty cycle to get table boost at that level. If thats what you have dont hen sorry, its not clear whether you have it set at 0.85 to run 0.85, or running lower-say 0.5bar with more duty cycle.
The lack of urgency at 12-13psi could be other things like the variable cam timing, sudden richness from AFM playing games etc etc. Not really the boost controller
https://www.sau.com.au/forums/topic/31632-avc-r-help/#findComment-642871
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
