Hi, new to the forum~
Anyway, will be getting my car this coming monday, however before i am getting the keys, I would like the mechanic to help me adjust the height of the car..
currently, it has HKS aftermarket adjustable suspensions on, which makes the car real low, too low for my liking since it will probably hit every hump.
the front of the car has a front lip which sits approx 120mm from the ground (in green) and would like the height of the green portion to be higher, like around 150-180mm.
so, am i right to tell the mechanic that i would want the front of the car to sit 150-180mm from the ground and for the rear to be heighten the same, so it will be even as well?
also I would like to ask, is ride hieght as measured as highlighter in the red?
https://www.sau.com.au/forums/topic/316349-r34-suspension-help~/
yep you can quite easily say i want my front bar this high and want the back to sit level with it.
provided your suspension is height adjustable any mechanic can adjust to your liking very easily. keep in mind youll need a wheel allignment after a height change
thank you :wub::action-smiley-069:
