Throwing this up in here in the hope of getting this done close to home.
For sale: 1997 EL Falcon XR6
*Body-352000km
*Engine replace and diff reco about 120000km ago
The good:
*4 brand new tyres
*New radiator, fuel filter and front rotors
*aftermarket exhaust
*Made roadworthy a couple of weeks ago, thinking that the certificate may expire before the transfer is completed, but in any case shouldn't be hard to get another one.
The bad:
*Small piece of surface rust on the roof(about the size of a 50c piece). Can be fixed with touch up paint.
*Tyres rub on the arm. I have been told that this may be able to be corrected with a wheel alignment and it is not a big deal.
*slight fluid leak from the diff
*came with a little front end cosmetic and headlight damage. I have repaired a majority of this inc a replacement set of LHS headlights
Should be able to get more pictures up later this week.
Bought this about a month ago as a replacement for my MR30 skyline, but after driving my MR30 on the weekend have actually decided I like the skyline better, and would prefer to upgrade to another R30/R31 instead.
Keen for swaps with an R30/R31 manual with low k's with cash adjustment but let me know what you have!
Other than that, if you want to buy it outright I am chasing around 4K neg.
this
in this
got bored and decided record the new exhaust note
new exhaust
i'll stop whoring now. actually can you please send pics to me, the falcon should be able to tow a car yeah?
Still got MT4 and R30. Will get to it when I get some time and money(soon hopefully :( ). Is it true you now have a DR30?
And the falcon's diff is now fixed! It didn't actually need to be rebuilt, it just needed some sealant on the thread to stop it leaking out the thread/spline after the seal had been replaced.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
