Yay finerly got rid of my camry and got my self a 1989 R32 GTST 4 door.
IT's in good nic with a kakamoto exhasut and unkown brand pod filter and lowered. (front lookes farked as it sit way low to the rear).
Time for me to hit hidden vally and start drifitng.
https://www.sau.com.au/forums/topic/316426-got-my-new-car/
That looks ace mate.
How do you rate the performance.
Im guessing its way better than ya 31 even though that went well.
Cheers Wayne.
Oh yeah.. Welcome to the(import) 4 door club
Hi agan wayne being a while.
performance is good, I would say handling wise the chassie is stiffer then the 31 and it brakes better then the 31 (even with r33 gtst brake up grade from al)
has a bit more power to. altho im starting to hate the lag from 0 to 3k when i put the foot down.
the 31 was a good car to learn in and with some time i could have made it nice but keep getting done by the cops and it keep brakeing.
gona take it to the drags this friday and maybe drift it to.
brentt
https://www.sau.com.au/forums/topic/316426-got-my-new-car/#findComment-5180715
  • 1 month later...
Nice car did you get this off Damien??
Yea i think that was him porn*injapan on boost yea
got it dynoed the other day at 138RWKW at 14psi
and 15.3 @ 90mph before winding up the boost.
looking at a r33 turbo and r34 smic atm
Edited by redliningr31 skyline
https://www.sau.com.au/forums/topic/316426-got-my-new-car/#findComment-5265463
Yea he's a good mate of mine. Very clean car when I saw it.
Ah go manual
Also look at the VG30 turbo it has steel wheels I got 204RWKW on 16psi with AVC-R and there pretty cheap and pretty much direct replacement. Some model RB20 have a different banjo bolt but thats easy fixed some time they can sut bolt on.
I have a few supporting mods to get that figure Nistune computer,040 fuel pump, FMIC, 550cc injectors, VG30 tubo, JJR coil packs All the Dyno work was done my Keelan at Peckys.
https://www.sau.com.au/forums/topic/316426-got-my-new-car/#findComment-5269280
Yea have being happy with it when i brought it and yes it is clean.
thanks for the advice on mods. ive got a 34 smic on the way and a r33turbo. will look at the vg30 later on. def will be getting a nistune and bosh 040.
at the moment im gona concentrate on suspention as she understeers alot (found out on last drift practice and motakana).
and manual will be when i can find the cash.
https://www.sau.com.au/forums/topic/316426-got-my-new-car/#findComment-5277352
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
