after getting everything ready for my new fuel setup
it dawned on me that issues with unused fuel returning to tank hot ,
could be aided by some type of cooling
i was thinking a small oil / trans cooler with a fan mounted to it might work
some thing like this
http://www.a1hiperformance.com.au/docs/pro...php?prod_id=335
im looking for suggestions / criticism so go ahead folks
what do you think?
Edited by shakotan-cefiro
https://www.sau.com.au/forums/topic/316491-fuel-cooler/
Except a car with 600hp willl heat up the fuel as it usually only needs 50hp of fuel and 5the rest goes round and round. I would say it isnt really an issue in a drift car, as they dont run for very long, and as rob said a good % of the fuel that goes into the rail goes into the motor, not round and round
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5178702
Waste of time match your fuel pumps flow rate to your power output with a safety margin of 30% and you won't have any issues with hot fuel.
1500hp twin turbo v8's...... idling around town with aeromotive 11102 's there is a whole lot of bypass.. hence why we use them. Application
http://aeromotiveinc.com/products-page/fue...&height=136
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5178766
using a cheap tranny cooler from super shit in the return line on my car. mounted it just behind the diff.
i dont see how you'd be getting hot fuel in a drift car tho, it takes a long time at light load for even a 044 to start cavitating, not like drift cars are at 1-2% inj duty for long
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5180674
Why the hell do you have two aeromotive pumps when 1 is capable of that horsepower. Why wouldn't you just you just stage the big pump and run an 044 as a primary? Surely a 1500hp car isn't going to be hanging around the streets for too long anyway
As far as formula's go. Multiply your injector size by the amount of injectors you have then add 30%.
Edited by rob82
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5180792
RE-READ my post "twin turbo V8's" ..... im referring to multiple cars hence multiple pumps....
you would be surprised how many kms one of them does, frequently driving interstate.
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5181158
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
