The series one version of the Stagea was first produced in October 1966 until late 1998
LOLZ!
1966 never seen one that old.
Thanks for what I think are meant to be positive comments. It is/was my first attempt at a website so there were always bound to be mistakes. In fact almost all the info that was wrong came from wikipedia .
Will be getting an update soon .
Good info. While I've had an RS Four since 2006, have just acquired a 25G for my son. Out here you must have an open, 3 yrs experience, before you can drive a Turbo.
I noticed you listed the 25G as "Basic". Well apart from the tweeters in the A pillars and the electric tailgate closer it has all the refinements of the RS Four.
The way these cars were originally bought JDM is a long way from the basic models.
The nice part about the two Stags is that they loo identical, even down to the N/A grille. LOL
didn't realise it was your site
seems like there is a bif of info on there
needs some bits and pieces about the rs4s's :(
Because of age the RS Four S has only been available in the uk recently so there not much info on this model over here yet.
Edited by RSVFOURUK
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
