  • Replies 53
All I have heard is complete praise for Dunlop FM901's. You may also find a set of Bridgestone RE711's will give you similiar ride quality when compared directly as an Ultra High Perofrmace tyre... each to their own.
Otherwise, Tire Rack will give you in-depth reviews, specs & ratings for most treads on the market. (Ie. FM901 Review)
https://www.sau.com.au/forums/topic/3167-tyres/page/2/#findComment-56171
I eventually got a set of Bridgestone S-03s put on today..
I havent had a chance to give them much curry.. but the little squirt around teh round about I had was impressive.. now I just need a better suspension setup :confused:
For the azz end I got a pair of 255/40 17, and the front 235/45 17..
Cost me around 1300 for the set.. *sighs*
I'll give them a decent road test and let you know how they go.
https://www.sau.com.au/forums/topic/3167-tyres/page/2/#findComment-57576
got Falken 451's, heaps heaps good. Can't fault them, apart from the rears tend to spin up off the line(traffic lights!!)
235x45x17 front
255x40x17 back
Fronts have worn a bit on the inside, but this is due to camber/allignment.
both have done about 35,000 and still have at least 35% tread
Good in the wet:uh-huh:
https://www.sau.com.au/forums/topic/3167-tyres/page/2/#findComment-57590
Well.. WHAT CAN I SAY!?
Took my car up through the twisties on these new tyres.. in my RWD 170rwkw gtst I out drove an r32 GTR, WRX, and an r34 GTR.. the car was on rails, and powered out of corners like no tommororow, they love the wet.. I was taking 80k/h corners at 5-6k rpm in 2nd gear with no wheel spin on wet roads.. and still powering out of corners..
im impressed.. i can not speak highly enough of them.
https://www.sau.com.au/forums/topic/3167-tyres/page/2/#findComment-58347
I've had a number of different tyres on my car in teh 2 1/2 years I've had my car... IMO, best bang for your buck tyres are the Falken Azenis ST115's... They're slightly more grippy than the FM901's, and slightly cheaper... On the downside, they don't last _quite_ as long... But still have a reasonably good life... I got almost a year out of the ones on the back of my car :D
matt
Originally posted by ex-static
Im thinking of spending about 1200-1300 all up.
also.. ive heard from multiple reliable sources that skyrines perform better with 255s on the ass, and 235s on the fronts..
https://www.sau.com.au/forums/topic/3167-tyres/page/2/#findComment-60599
The guys at the tyre place I am dealing with are suggesting the Pirelli P Zero Nero.
They reckon its grip is up with the best, but the ride quality is a lot better than most low profile tyres.
Anyone had any experience with them?
A set for mine will cost about $1800 fitted though.. ouch.
https://www.sau.com.au/forums/topic/3167-tyres/page/2/#findComment-60802
faulken grb's
for all you tight arses.. 255,40,17 i got four for 760 fitted and balanced
sure they dont gip as well as the yoki fl e-specs but i find that the only tyre that can hold up to a full day of drift at the creek without rippin the tread of to be fulken zeix(ful **** house) and the grb
downside is they dont sell the tune 2's anymore which were the grippier version, fk451 have slightly more gip than the grb's but they wear out extreamly quick(for the record they were 210 each). the st115(supposed to be good never had a set but they do were out as stupidly quick 270 each)
temple tyres 190 each sure it run by kabobies (several people said sic car bro is it a gtr)but i was in and out within 20 minutes. nice service i higly rcommend. especcially if you have been to a bob jane and they take 1.5 hours to get your car back on the road(but they do have a coffe machine)
pete
https://www.sau.com.au/forums/topic/3167-tyres/page/2/#findComment-61986
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
