I have started a new topic so you all can easily see what parts I still have for sale and how much they are all now reduced to.
Rear Lower G13 Adjustable arms R32 (on right) -NEW $100
BeeR Fuel Rail RB26 blue anodized -NEW $200
2x Front 6 piston 2x Rear 4 piston Brembo monoblock Calipers off a Porsche GT3 Cup Race car + brand new dust seals still in bags - USED
+ 2x Billet Adaptors to adapt front calipers to any r32-34 Skyline
+ 2x Front 350mm heat treated disks with alloy centre hubs. - NEW $3,500
ATS Twin plate carbon fibre clutch - NEW $1800
ATS 1.5way Rear LSD R32 GTR -USED $700
Billet Steering Adaptor ALL NISSANS - NEW $70 (top)
HPI Engine Dampener Rb26 R32 GTR - NEW $250
JIC Adjustable Front caster rods R32 GTR -NEW $250
Greddy Trust T78 Turbo kit suit RB26 No turbo Included but everything else you need! Just buy a brand new TO4z any turbo with a t04 flange and your off!
Included : Stainless exhaust manifold suit RB26, Greddy wastegate, Greddy Hard alloy piping, stainless steel braided hoses, Greddy blow off valve, stainless trust head shield, all silicon joiners and hose clamps required, exhaust wrap -USED $1,400
Noltec Sway bar linkage bush kit Nissan (suits all skyline) - $50
NoltecRear lower control arm bush -R32 +300zx - NEW $60
ALSO FOR SALE BUT HAVE NOT TAKEN PICS YET:
HKS TA45 Turbo kit suit RB26
Included :Hks TA45 turbo no shaft play,HKS RB26 castiron single turbo exhaust manifold, HKS 50mm waste gate, Wasted gate dump pipe, HKS cast alloy piping needed to convert to single turbo including twin-to-single AFM-to-Turbo pipe - USED $1800
Greddy Profec Eo1 Boost controller -USED $420
R32 Crystal Red LED Taillights -NEW $250
Sard Fuel Pressure Regulator - USED in box $120
Spitfire Coils RB26 - USED in box $450
OS Giken Pull to Push clutch converter (put a push type clutch into a r33) USED in box $200
R34 GTR wheels SET OF 4 with caps In great condition, only one slight scratch with worn out - USED $1800
All items in EXCELLENT condition even if used.
Located in Sydney - Kellyville will post at buyers expense
Call Jake on 0404 080 448
[email protected]
  • Replies 40
Also have:
Silver R32 GTR bonnet with small dint $300
Silver R32 GTR boot with spoiler and badge $320
R32 GTR front indicators Pair $130
Hi,
I would like to buy the Sard fuel pressure regulator.
I'm a local and can pick up if you get back to me ASAP.
Thanks
Super Keen on the Boot and the Bonnet. Mine were stolen last week (CF Bonnet, Cwest on Boot)
Please PM /Ring me. I left my Mobile number on yours.
GTR is also Silver and these will be most welcomed.
Edited by Sinista32
  • 2 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
