hey guys
i own a r32gtst
me and a mate got pulled over and defected last night, he claims pulled us over because he heard our bovs..
anyway we got defected for bovs, front mount, and exhausts.. he could of got us for heaps more but didnt :cool:
we both got red stickered and need to be passed by a full inspection...
just wondering what else i have done that wont pass
apexi intake (pod boxed)
rb25 turbo
greddy spec b/c
turbo timer
catch can
split dump
pwr radiator
they shouldnt find out i have upgraded injectors fuel pump and nistune will they?
what about
20% tint i think
boost gauge on pillar
coilovers
none standard gear knob
everything else should be sweet
bodykit?
18inch rims?
gtr bonnet?
any help would be great, and if anyone in the newcastle area has a standard exhaust,bov and side mount i could possible borrow for a while or buy would help alot thanks
https://www.sau.com.au/forums/topic/317141-defected/
That is far from true, some mods are legal and some are depends what state you are in
and we are talking about NSW, ALL NON FACTORY, NON STANDARD ADDITIONS TO A CAR IN NSW IS A POSSIBLE DEFECT, even with engineering certificates.
This topic has been covered a million times, the conclusion that is always reached is if a copper wants to defect you he will, so best is to be straight with them and they might cut you some slack.
You CAN get defected for trivial things like a gear knob.
There have been people on this forum being defect for having a pod in an engineered custom made box, they may not get defected because they think its a fire hazzard, but they use the EPA route instead, and we all know that most stock standard RB's will fail an emisions test purely because they arn't spring chickens anymore.
Use the search function and you will learn a thing or two, i keep saying this but no one seems to use the search function anymore.
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5187534
and the only mod i can think of thats technically legal is changing an R33 wheel size from 17 inch to 18 inch aslong as spacers arnt used. But even then your not 100% safe as they can always defect you and make you prove there is nothing wrong with it.
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5187540
ahh also car has to be atleast 10cm from the ground...... but then you get raped for changing the suspension.
If anything if the car looks modified even if it is completely (technically) legal they can always find something wrong with the car get you for not having the gear position sticker being visible, seatbelts retract too slow ect....
Its not fair but thats how it is
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5187549
this thread has been moved, when i first posted it was in the forced induction section, now that i know its an NSW issue i will leave, no idea whats allowed and whats not in NSW.
ok now it makes sense lol.
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5187940
not everything aftermarket but most things on your list there are asides maybe the bonnet and radiator provided its installed professionally....as for the injectors / computer well really depends on how rich your running amusing you have got it tuned? All they really have to is take the car to a defect station and run an emissions test, ive have known people to basically go back to standard everything inc computer just so they could pass.
really its just cops wasting your time and money and they will always find a way to do it , these days even engineers dont help :)
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5188047
This is entirely incorrect, however the problem of ill informed officers being able to write up defects at their discretion doesn't help.
I know what you mean, but an officer can defect you for anything even if its not officially a defectable item. At the end of the day your still getting defected and you have to prove that its not.
So no its not correct to say everything is a defect, but everything can be defected
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5188374
My 2c;
apexi intake (pod boxed) - swap with stock airbox
rb25 turbo - leave it, unlikely they will notice
greddy spec b/c - will have to be completely hidden, probably best to just put the stock stuff back on
turbo timer - ??
catch can - will be fine as long as its plumbed in properly (no venting to atmosphere)
split dump - probably ok
pwr radiator - will be fine
upgraded injectors fuel pump and nistune will they? - should be fine
20% tint i think - IIRC 20% is legal...
boost gauge on pillar - if its right down the bottom of the A pillar, it should be alright. If you can touch it with your head (imagine being in an accident) then it will have to go
coilovers - probably ok
non standard gear knob - will be ok if the gate pattern is shown on it or nearby
bodykit? - probably ok as long as there are no sharp edges (think of what happens to a pedestrian in an accident) and it must be more than 10cm from the ground
18inch rims? - could be a problem, there was the +1/+1 rule at one stage, ie you can go one inch wider and one inch larger in diameter (as long as the tyre rolling diameter is the same). But i'm not sure about +1/+1 any more. Probably best to borrow some stock rims with tyres with plenty of tread.
gtr bonnet? - should be fine
Also, make sure there is 10cm ground clearance under the car (exhaust is usually a problem if you've set the coilovers low) and replace the stock bov and SMIC as you already said. If you've cut the bodywork for the FMIC that can be a problem.
Then it depends on how nasty they want to be, if they're not too bad you'll get through with the above.
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5188461
20% tint is NOT legal. At least on the driver and passenger windows it's not. Cops rarely give you trouble for tint though... I bought my car with everything tinted but the driver+passenger windows, and I gotta tell you. I f**king hate it. I can't see a f**king thing AT ALL while reversing. :) Thank f**k the dumbass didn't tint the other windows lol.
Sorry went a little bit off topic there.
Boost gauge on A pillar will most likely have to go because even if it wont hurt you in an accident, they'll probably get you for obstruction of vision. Yes even if it's right down the bottom.
They'll spot the coilovers in a split second
Definitely remove the boost controller...
Just change most things back to stock and you should be OK...
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5189339
when i got red stickered all they did was check that the defects were fixed up, you dont have to get a blue slip, you just have to go to a place that does blue slip inspections. anyone that tells you otherwise is either looking for a bribe to pass you or has no idea what they are doing.
i mean, if they defect you for ride height and make you do a full inspection, why arent the laws to just defect you for nothing in particular but make you do a full inspection? does anyone get my logic?
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5190344
we already know that the excuse to defect is more a means to check your car for other illegal things, allot of the organised crime syndicates used to and still do mods to cars to legitamise some of their cash flow instead of spending it all @ the casino...
The way it used to be seen is there was a good chance that a modded car had illegal/legal drugs, stolen id's, credit cards, wepons ect.....
Now its different with the sharp rise of customising and modding cars by all people of all ages and demographics.
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5190462
Keyword Joe - Logic
The same logic that says loud exhausts on cars are a no no, but harleys can go for their life.
The same logic that bans coilovers, but a 30yo rust bucket with leaking shocks is all good.
bikes need everything they can get to be noticed, especially when they have zero lights on the sides and even a small nudge could mean the end of someones life. i've just gotten flush front blinkers on mine so when i change lanes my indicators are noticeable from the sides. my rears are now LED and i still dont feel safe. im going to chop my exhaust so its a little louder too.
and have you ever heard stories of OEM parts breaking for no reason?
what about the parts that come from china?
ive heard LOTS of stories of things like tie rod ends breaking apart - but OEM parts have been built to a standard. aftermarket parts dont, and we're talking about the bad quality stuff because its not like the govt will ever say "only tein, koni, buddyclub and whiteline suspension parts are allowed". its about liability but getting an engineer certificate counters this. if you've got quality parts and its been installed correctly you will pass as well as have a safe and legal car with upgraded suspension. obviously this goes for most other mods.
https://www.sau.com.au/forums/topic/317141-defected/#findComment-5191097
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
