Lol ^
There is no evidence that flutter damages your turbo, so it is hard to say how much if any damage it would be doing. Personally i think it does damage the turbo, but if you are worried about it then just remedy it with a good plumb back bov
kkr :) ..wat bov "if so" r u currently running?,and i wouldnt worry bowt the flutter too much (that is unless u dont like it).I Had no bov on my old 180sx for nearly 5 years runnin a T28 running @1bar everyday and never had any problems at all and luvd the flutter :D
There IS evidence actually mate.
Ceramic turbo's last long under surge. Steel wheel as found in R33s can handle it, they'll usually end up with shaft play before the turbine blades go, either way it is bad for your turbo. The more boost the worse it is.
If you want to fix it straight away, either loop the intake to skip the turbo, if you have a boost controller - cut out boost altogether, and rectify why your blow off valve isnt opening.
It would be very hard to prove that compressor surge was the reason for any turbo failure, hence there is no actual evidence to demonstrate that. I know people that are running 12-14psi through ceramic turbos with no bov, and have been for years, yet their turbos still have very little to no shaft play. On the other hand, my mechanic showed me a turbo that he had been running in his R33 GTS-T for 40xxxkms and never fluttered, the shaft had way too much play.
Having said that, i am on your side, i believe it causes damage and should be avoided. I am just saying there is no physical evidence that can be solely contributed to compressor surge
Edited by Hanaldo
Then what you claim is there is no evidence, in ANY case, regardless of any setup, to say that anything caused turbo death or extended its life. What would have caused it then ? stock turbo's don't blow teeth off... :)
Its highly likely that bouncing 10psi at 7 grand back onto ceramic blades will cause those blades to break free. Any that doesnt is simply a factory freak.
That's the thing, it can't be proven beyond any shadow of a doubt. Personally i accept what evidence there is (eg. what you said above ^) as flutter is bad and causes damage. But as far as firm concrete evidence is concerned, there are plenty of stock turbos out there fluttering away happily. I forget what magazine it was in, pretty sure it was HPI because that's what i read most, but there was an article in there about testing done on a stock RB25 turbo where they literally fluttered it to death, and yes the blades blew sky high. But the final verdict was that the result was not conclusive because there were too many other factors. The turbo had already travelled 120xxxkms, and who knows how hard it had been pushed or how poorly it had been looked after. The fact that the wheel blew under flutter could simply be an indication that it was already damaged.
Oh and Im guessing somebody will come back with "oh but Ceffies didnt have boV from factory and their ceramic turbo's last just as long" - yes, but factory turbo ceffies boost less than 5 psi... which is safe enough for ceramic, can probably handle a tad more. Steel wheel can handle alot more on top, but for "massive flutter" you need some seriously high pressure.
Edited by Nic_A31
This is probably where we're dissagreing.
What death exactly are you thinking of?
Im saying that high pressure going back towards a compressor will rip the blades off the wheel.
Immediately slowing down and speeding back up (surge) can cause the shaft to snap, or contribute towards shaft play, and shaft play / broken shaft can also be affected by prior life of the turbo (kms, oils used, treatment etc), such factors cannot possibly cause the blades on a wheel to come off ... that can only be caused by excessive feedback.
Edited by Nic_A31
Yeah like I said, shaft play / snapping / any shaft drama' is caused by any or a combination of issues. Spinning at 200'000 or 300'000 rpm, then being forced to go the other way in less than half a second certainly doesnt help the shaft live a long and happy life.
Hey guys, thanks for the reply's.
It hasn't had an Aftermarket Bov installed so I'm guessing that its running stock if not, none at all.
so the Kkr isn't such a good turbo?
would you please suggest A turbo that would be a good replacement, here are my engine specs at the moment
Engine: Rb25Det
83000kms
KKr430 turbo
High Mount Stainless Manifold
38mm Wastegate
HKS AirFilter
Front Mount Intercooler
HKS HI Power Turbo back 3 1/2" exhaust system
Bosh 044 External Fuel Pump (in tank)
Iridiums
HKS Turbo Timer
Turbosmart Manual Boost
there's A link to my car, you can clearly hear the flutter
Wow, this thread is full of fail.
What has ceramic wheels got to do with failing due to flutter?
The ceramic wheel is on the exhaust side..
The returning air does NOT stall the turbo, and it does NOT make it spin the other way.
The only thing it will be doing is putting a bit of extra load on the fins of the compressor wheel as it tries to push air into the returning air.
Edited by bubba
I agree with bubba, build a 25/30!
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
