  • Replies 92
the million dollar question i mentioned Grant, ABS pump replacement. tune check. boring arse jobs but they need doin....
Just the routine maintaince eh?
Any chance I get to exprience the torque of the 2.8?
I know I've gone off topic so meh.
lol! fellas im a bit of a granny driver on the roads. due to being a rescue worker n all. ive seen too much nasty shite out there to wanna have it happen to myself. Yea my motor is awesome but i ran outta money to fix up the suspension etc so i cant exactly implement all the power i have available. bit of a downer huh.... track work FTW!
Trent,
That is quite a rant, these clamps are too chunky for my liking anyway. And you bin about 30 of these a week?!
Will have you to replace the standard ones with the one you put in my R other day when I'm ready to shit my pants with more killerwasps.
Cheers
Grant
cause the boxes i started putting them in got too full, i reckon at least 100-150 in boxes :happy:
i put one of the good ones on your GTR the other day :)
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
