Sliksilvia, right on the money man... I took the car down to a local pro installer and he said straight up that even though you may have heard good reviews of Jaycar amps, they're plain SHIT!!! He put in a ground loop isolator and what do you know, no more engine noise. He said they've seen alot of Jaycar stuff that just isn't up to scratch... I paid $225 new for my little 2 channel amp, after reading some reviews about it, but I think from here on in, no more shitty brand stuff for me.
Thanks heaps guys.
Again guys I do apologise for the apparent 'grumpiness' above. I should also make it clear that this is in no way directed AT 95GTST and his issue. :cheers:
It's just that day in and day out we have numerous (usually young) customers coming in with the same problem and all I do is change their RCA's, redirect them or put in one of our amps temporarily to show them and nearly every time the issue is solved.
They sit there with a mountain of electrical textbooks looking for some magical explanation on why they have this noise when the real issue is that they have gone for the cheapest stuff they could find. I know in theory cables shouldn't make a whole lot of difference but everytime I switch an old set of Aerpro RCA's with something like Stinger Dream's the results speak for themselves... :cheers:
more personal experience here, i got my alpine deck n coustic amp all hooke dup for about 6 months with NO interference problems whatsoever, the other day i isntall a TV screen n xbox into my car, i have ALL the wires running on the passenger side of the car, including the power on wire for the amp, i used basic AV cables for the TV n sound and i get interference when im playing the xbox the same interference your having that goes with the engine revs, but i swithc to play an mp3 direct form the head unit and there's no interference, so im guessing that coz i bundled the wires right next to the battery thats the problem, or perhaps thye are cheapo AV cables, coz my RCAs for the head unit are stinger RCAs, so my question is, where can i buy proper quality AV cables ? like the red white n yellow ones that wont get nterference ?
Also, if you altenator is not earthed properly it'll cause some wired problems, we have had a few people with problems like that, and with skylines (r33's), their earth is in a bastard of a position - e.g. it doesn't run right up to the engine, so it really relys on making perfect contact with the chassis.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
