i have 1 month old ROH DriftR wheels/tyres
front 18x8 (tyre Falken ZE512 235/40)
rear 18x9 (tyre Dunlop LM701 265/35)
they fit my R33 no rubbing, reason for sale is due to change of jobs my wife will have to drive it now & then & if you see what she has done to VT wagon mags you would now why (she is a good driver just scraps gutters parking).
offers over 2K accepted, don't waste your time offering under that because i will just keep them.
if you need pic go to ROH web site.
https://www.sau.com.au/forums/topic/31774-roh-driftr-wheelstyres/
justinfox... you don't have to have all the wheels the same size, as long as the rolling radius is the same. Alot of people have experienced problems with their ATESSA by not having the the wheels the same (rolling radius).
you can have rims that are smaller, and tyre walls that are larger, etc. But this is a REAL hassle to arrange, so it's best if you keep tham all the same size.
For your interest here is something I found a while back...
http://www.miata.net/garage/tirecalc.html
This lets you try different combinations of tyres / rims and gives you the rolling radius, when compared to stock rims it will tell you if your speedo is going to be out and by what percentage.
This also shows that no 2 combinations are identicle, unless you want to put something like 185/60/15 on your GTR (which won't even fit around the brakes!).
After this, as zRoyz states, you then have to take the cars setup and balance into consideration, and this is where the offsets are important.
There's more to fitting new rims than 'these ones are nice'.
Good luck with the sale zRoyz, these rims look great. A mate of mine DJR33 put a set on his car a few months back!
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
