  • Replies 149
yes, Dean, wtf is going on? :D ... cmon we are all busting to know where and when :)
p.s. does anyone know what time is what at the ute muster? I was thinking of going and checking out the ferals (SAU company excluded John, Martin and Henry :( ). Anyone know the schedule?
Ok im sending out Pms on meeting spot now. Im still not entirely sure on where we can go cos i havent had a spare minute to go out and do the route i wanted to, so instead i will do somethin that everyone wants.
So suggestions here if u have any, otherwise i will work out somethin from now til sunday, or someone will suggest somethin then? Also does anyone wanna have a lunch break stop?
Cyas
People I pm'd:
midnightslider
legend
The Jester Of Oz
skidmark
nismostu
N/A®
hippy
Steve
4door_Sleeper
Jase
cell
paullys 32
P1E
TIMMMAYYY
Nightcrawler
VIPERGTSR01
If u r not here, that means u havent been sent a pm.
Cya all there :)
I notice some of the old schoolers like whatisname, Bugalugs, grepin and freebaggin are missing from the list.
It's UNAUSTRALIAN not to cruise on the Australia Day long weekend!!!
.... I guess I could kinda be an old schooler, as I turned up on the scene around the birth of SAU - not unlike yourself :)
Pity Rob sold his 33, Andy sold his 33GTR and Pawley has disappeared from the cruising scene :P .... so many memories ....
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
