Hi Guys,
Over on the classicZCars (240K forum) forum, we are currently trying to get up enough interest in a fibreglass or fibreglass/carbon fibre bonnet for the C110 240K (should fit both hardtop and sedan).
I found somebody who is willing to make them, but i don't want to waste his (or my) time if we can't make up atleast an order of 5 or 6 (it is a lot of work to setup the moulds.. other places have wanted $1500 just to make the mould!), we currently have 4.
Details in post number 49 : http://www.classiczcars.com/forums/showthr...3120&page=2
anyone here interested? if so pm me.
Kent
https://www.sau.com.au/forums/topic/318359-c110-240k-fibreglass-bonnets/
Hi Guys,
Kent
Kent, not sure how many people on here have a 240K, from hanging out here for a while, lots have the C210, not the C110,
But I hope some more put their hands up, as I want one.
Nigel
Edited by noddle
i am afraid that at this point, i have no idea.. the guy making them won't know either until he makes one. He used to own a fibreglassing business, and supply prices have obviously changed over the years.
at a guess i would expect a fibreglass bonent to be around $500+ and a full carbon bonnet around $1000+.. no idea for a mixed one.
as a comparison, a carbon/fibreglass bonnet from restored in Japan is around $1200
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
