Gday all
My hicas is getting pretty noisy so i think its time i do something about it. I had one lined up to buy about a month ago but fell through :-(
I have found another for sale but its off a r34gtt, would it be the same, length and senors?
Any help would be appreciated
Cheers
https://www.sau.com.au/forums/topic/318455-c34-hicas-series-2/
i put a r33 gts35t one in mine . well i would have . the stagea one has the motor pointing down (FAIL) the r33 one has the motor pointing backwards way higher up .. the plugs and sensors are all the same . a skyline one will bolt in but 1 or 2 of the plugs are to short by a couple of inchs
have you checked the 4 ball joints ot the two bolts that hold it to the subframe ? gievn the amount of work the rack actually does i highly doubt its worn out
jack ut up and get some gorilla to try and "steer" your back wheels while you look to see whats sloppy
the noise is the actual hicas motor, it sounds like a cheap noisy fuel pump when i pull up to a set of lights or moving very slow
Sorry Punk72, I get a bit slack some times. Send me a PM $20 should cover freight and it yours
I actually posted a month or 2 ago about my replacement hicas bar being too short
It is suppose to be a R33/34 hicas lock bar
I measured it tonight
The stagea hicas rack is 425mm long
The hicas bar is 405mm long
So this was giving me major toe out
Will have to sort it out tomorrow with Justjap.
hicas does nothing below 80 kays ???????? .
put it in hicas diognostic and it will make the rear wheels go max letf to max right and back to centre every 2 seconds while the car is stationary so you can look under it and see what it is
Just because the hicas isnt in use doesnt mean its not running? i have pulled up and it was still doing its noisy thing so i jumoed out and felt everything around the hicas area and the
only thing that was vibrating was the black motor looking thing in the hicas setup.
I am going to have to give this diagnostic thing ago and see what happens.
cheers
  • 1 month later...
update on this hicas problem,
bought a r33 hicas motor and swapped it over, noise totally stopped for a good hour of driving around town, then slowley came back getting louder and louder to the same as before :-(
In the mean time I have been searching the web and found a couple of pages say that if there is any problem ie motor or sensor stops working the hicas is unable of moving make it from 4 wheel steer to 2 wheel steer,
So I disconnected the motor and took for another drive, No noise!!
Has any one done the same for a long period of time and found any change?
  • 2 months later...
another update on the hicas problem
bought a set of tomei hicas shims for $80 and locked the bloody thing off, gutted one of the spare motors i had and put it all back together.
looking at it you cant tell the difference everything is plugged in and looks stock.
noise has completely stopped and the car feels a lot tighter.
and removed the hicas dash light
I pulled a r33 hicas rack apart to see if i could find anything that would cause the noise, but only pulled half of it apart as i didnt have the right tools. One day
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
