For sale:
1990 Nissan R32 4 door - Turbo manual
km's: 12x,xxx (have had it since 70,000 and most is highway km's)
The Car used to be Non-Turbo Auto, but is now Turbo Manual...the conversion was done properly and has been very reliable for the last 10,000kms. Most of the time this is just putted around as to me its just a daily As i have a track 180sx as well.
Car doesnt have HICAS at all, and driveline and brakes, 5 stud hubs are all GTST now and the diff is a stock LSD.
RB20DET
5 stud conversion
R32 GTST Brakes + Brake booster
Turbo LSD
Velour Late model seats and trims
Swapped All side glass out (as it was tinted)
3" Cat back exhaust
Manual conversion kit
th_Hawker180_R32cooler.jpgth_Hawker180_R32engine.jpgth_Hawker180_R32Front.jpgth_Hawker180_R32inside.jpgth_Hawker180_R32inside2.jpgth_Hawker180_R32rear.jpgth_Hawker180_R32Side.jpg
The Car:
1990 Nissan R32 GTS
RB20DET (originally RB20DE)
5 speed Manual (originally Auto)
Engine mods:
Stock RB20DET
Stock Turbo (genuine 55,00kms on turbo when i put it on)
GReddy Return flow Intercooler
K&N Panel filter in stock airbox
Spitfire coil packs
3" Cat back Exhaust
Walbro Fuel Pump (Genuine)
Turbo Radiator
Exedy 5 puk clutch
Electronic:
GReddy Profect Boost Controller (not setup, just using it as a guage at the moment) Boost is bleed with a bleed tap (0.9 bar)
Suspension:
KYB Lowered Struts and springs
5 stud conversion - R32
R32 LSD Auto - (originally single wheeler)
R32 GTR rear swaybar front is stock
Exterior:
Rare 4 door Type M Skirts and bibs
Dark tint all around
Tow bar, great for 6x4/motorbike trailer etc...
Interior:
Velour Late model 4 door seats out and trims (originally grand-pa spec) - these are awesome condition!
Skyline floor mats
GTST steering wheel
Blaze gearknob
The bad:
It has 2 large scratch marks from keys (both before i brought it), one on the bonnet and one down the passanger side.
Rear guards need some paint as i rolled them to suit the wider wheels.
Front bumper has scrapes on it
Car currently has Work Meisters on it, would perfer to sell with stock wheels at a cheaper price but could come with the other wheels for extra of course
Price: $8,500 FIRM with stock wheels
$9,500 FIRM with Work Meisters (Black centre 17x8 +30 and 17x9 +30)
No SWAPS, unless you have a BA Ford Ute/Sedan + money
no RWC, Photos are pretty old, can post up some new ones with the nicer seats/steering wheel as well as the current wheels.
Edited by Hawker180
Did you use the original RB20DE or drop another RB20DET in there? Is it registered with VicRoads?
Is the car currently registered? If not when did the rego expire?
What do you reckon is required for RWC?
Cheers
Its is another engine out of a donor skyline I purchased. So a stock RB20DET. New engine numbers and Turbo has properly gone through vicroads as i also did the Brakes etc... It didnt require an engineers certificate.
Still registered (rego expires in a few days, but i will renew it so it will have 12months rego on it)
For RWC im not thinking much, but its hard to day. I reguarly maintain it so i dont expect too much will be needed.
Im going to pull the clutch master off this weekend as it is leaking, so that will be fixed
Edited by Hawker180
Some decent photos, The insides of the car hasent been cleaned yet, so its just AS IS!
A few things i forgot: Brand new battery, Timing belt and water pump done at 117,000kms, clutch only 10,000kms old (Exedy 5 puk)
Edited by Hawker180
  • 2 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
