I've had another thought too, in that I could get Unique Autosports on board and persuade them to pursue this option to increase their parts lineup...
That way, perhaps they can purchase the original front lip and lend it to us.
If you could get me a list of all the different materials the copy can be made out of, and a write up of their strengths and weaknesses in relation to the original plastic lip, I'll be able to present some (hopefully) attractive options to John (owner of UAS)...
This way, your contact might be able to make some more money out of this project through UAS's sales.
I missed that one...
Firstly, I'm sure they would have considered this path, if not there must have been a reason. Secondly, perhaps you should approach John first, & if he is interested, he could give some estimated quantities.. then we have a start.
But before I can start with material compound options I need to show them the product, raw. So if the option with John works out, & he agrees to send a sample to melbourne, we're off and running.
  • 1 month later...
not sure if it helps but i sell the whole bar (fibreglass) for $300 ea. could possibly consider making a mould of a lower lip but it depends on how many i will sell. cheaper for a group buy can be arranged so let me know if your interested. 0413 714 354
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
