um, hoses are a mixture..Some are silicon (the best stuff), which isn't cheap. The other is just some stuff that was available in red. Its water hose, which means its even stronger than needed for vacuum hoses.
All the hoses i got in melb at a place called Purple Pig (specialising in hoses). Not sure whether they have it up here.
I think i remember seeing some silicon hose kits in Autobahn for about $40. Another option.
Whats involved in doing the cam covers/rocker cover? how many time do u need to sand and polish it to come out nice?
You have to take them off. That involves getting the cover off, and then under there is the screws for the other sides. Take them off, put them on newspaper and start going. You'll need some heavy wet and dry sandpaper to start off with (120 grade or so) and then gradually move to finer and finer stuff (1000) to get the really shiny finish. Autosol is a metal polishing cream which also helps inbetween sands (autobahn, supercheap, kmart, etc).
You can also take it to a metal polishing place, that can do it for you, and probably give better results than by hand.
You could always try Tony Powell plumbing supplies at Geebung, he usually has alot of good plumbing stuff and other pipes...
Also on the notion of polishing...
I did the rocker cover on my SR20DE, all you need is some 600 sand paper, then go 800, 1000, 1200 wet and dry and wet is the best option, then get a polishing kit from Bunnings that attaches to a drill ($30) and some rags and of course wax and grease remover and finally some metal polish...brasso everyone seems to have here...
Took a while cause I was drinking...but came up better than a mate who paid $120 to get his done "professionally"
Looking at doing the line's covers one day...
  • 1 month later...
Rocker Covers aren't so easy to get off. If you have changed the spark plugs before you'll probably know most of the stuff you need to get off to get to them. Its mainly just getting the intake piping and things like that out of the way.
You can probably see the outside screws. The inside screws are in the plastic cover. Once you undo them all they just lift off. I don't believe you need a torque wrench for the cam covers to put back on - i definitely didn't use one. You shouldn't have to replace the rocker cover gaskets unless you somehow damage them while removing the cover.
So really its just a disassembly process. It took me I guess 30-40 mins to get them off.
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
