hey guys i am thinking about selling mt r32 gtst skline.....possibly selling it cause i would like a change....but having said that im 100% happy to keep the car too cause it owes me a heap and all the bits ive bought are new so i know its all good....
mods that i can think of just quickly are.....
*NEW 500hp roller bearing turbo brand new
*NEW modofied exh manifold
*NEW 600x300x76 bar and plate cooler with 2.5 inch mandrell pipework
*NEW microtech lt12 plug and play ecu
*greddy type s BOV
*NEW custom aluminium oil/air seperator
*New 500cc injectors
*NEW malipassi RR fuel reg
*NEW 600hp brass button 5 puck clutch(i can chirp 5th gear at like 120ish)LOL
*kyb climb struts with rsr lowered springs(handles awesome around the track)
*alloy strut brace
*hi/low boost switchable boost controller
*endless brake pads
*hks power flow air filter
*3 inch mandrell bent exhaust with a custom dump pipe for the new turbo
*sweet stereo inc alpine head unit jvc amp and magnat 12 inch sub and pioneer and sony speakers mixed up brands but it sounds great
*enkei RP02 17x8 forged lightweight racing wheels with near new tyres
*NEW autometer pro comp 30psi boost guage
*interior trim is the same as a gtr32 the sweet felty stuff which is rare in a gtst
*NEW hi intesnity led single stage shift lite mounted in the instrument cluster
*currently making around the 300rwhp on 15 psi but will be upping the boost to around 22 psi soon.
heaps of other bits and pieces too but thats the main things i can think of at the moment....
**id like a sr20det silvia or 180 but a rexy would also be nice.... i guess anything thats worthwhile getting is always good ,the price i have to sit down and work out if someone is serious about buying the car all i can say for now its over 20k which may sound steep but the car should be seen to be appratiated.... mild ones in the trading post still go for ~20k in some cases at yards so i think that mine is a reasonable price given its condition and modifications.... thanks Jon :headspin:
  • Replies 45
just thought id tell yas i just added a new thermo fan so bye bye vacum clutch fan :) and i also got a new radiator cap and redid all the cooling system as a precautionary measure with it been summer at the moment...i also had the air con all checked out too... :headspin:
still for sale trade after been stuffed around by perple needing finance ... isnt it always the way hahaha :) could be interested in a swap plus cash if its not of even value intrested in mostly anything really thats worth while... just feeling like a change :D
im honest when i say it should run a hi 12... it has been due to run at willowbank for ages but weather has been bad of late.... only time will tell but... its just fast enough for something u can drive every day or like 300km's like i did last weekend... :P
as my location says im in s/e Qld toowoomba to be precise... id only be intrested if its sr20det manual and in sweet condition.... and it wouldnt be a straight swap...cheers Jon
i read other posts about your car it sounds okay but im in qld and u are act.... doesnt really worry me but it may make it a bit harder....depends how keen u are i spose...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
