  • Replies 193
Thanks guys. Was taken up at Mount Mee (you can click on them for more info).
Can't remember the specific walk or creeks name (I might have to try google it).
No Sam - might have a CPL on but that's about it.
(second shot is three exposures fused together though)
HI Beenar, I've just got a D90 with the 18-55 kit lens. Although when I took most of those historic race pics I 'borrowed' some long lens from work. Will confirm what it is tomorrow.
Yeah thought you were using something long, no way you are going to get that kind of DOF and Bokeh with the kit lense.
I almost bought a D90 but decided the Canon 40D was more suited to what I wanted, was a very tough choice though. I really must get my camera out and take some more shots.
Here's the rest of pics from the historics. THe first one here is my fav from the day.
Those two are awesome, would love to know what effect you used here
The first pic I cut the car on to a new layer, played with the colour values and sharpness. I then desaturated the background, added some blur and darkness to it to help the car stand out.
The 2nd pic, On the car I played with saturation, brightness and contrast, over sharpened it to emphasis the car's lines and and reflections. I then added a slight blur to forground and desaturated the enviroment a bit. The blur in that pic is just from panning with it as it drove in front of me. I used a slightly longer shutter than you'd usually use and just the panning right on (Through luck and multiple pictures, not skill haha )
Hope this helps :blush:
Cheers for that, they both have a bit of an unusual look to them, especialy the second one which to me looks more like a drawing then a photo, looks very cool, I like it
Took my misses out to Mrs Macquaries Point last night.. and i guess i had my camera still in the car from the morning.. So out it came and took some pics. Didnt have a tripod so was just resting it on random things. Wish i had a wide angle lens.. Only got the 50mm lens atm.. sigh why does lens have to be so expensive!!
Just a random pic of my car:
And this pic was just rested on a chair:
Peaceful place if you ever wanna take pics/take your other half out lol..
Your car is looking f**king sick man... Love it. Is it pearl white paint? Have a look at the 15mm 2.8 fish eye. Its an awesome lens for around a grand.
Cheers man!! Yup its pearl white, with yellow mica.
Even if its a grand i cant afford it hahaha.. Perhaps one day i will be able to purchase lenses.. Till then will keep using my 50mm lens hahaa
Just a quick shot from my hotel in Sydney CBD on Friday Arvo
Incredible :) Love it sam.
My 33...
Very nice :P Whats done to it? where is that location?
Very nice :) Whats done to it? where is that location?
Igloos at Rockhampton, Qld. Some weird old bunkers used in WWII
Ummm plenty of go fast bits, HKS GT-RS, HKS Cams, Plazmaman plenum etc - 340rwhp @ 14psi. Cant wait for 18 pound :P
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
