Put some pipes on my 3-2 which has 3in dump back, decat and a scrumy res. Car was very loud so i cut the res out and fitted a GONZO muffler. (unsure if ppl no what they are) it made it quiter but still had bad mid range loud drone which sh*ts you to death driving to work everymorning.
so was wonder whats best res or centre muffler to use to have a streetable straight piped 3-2?
https://www.sau.com.au/forums/topic/318985-straight-pipes-on-3-2/
straight pipes is exactly as stated. a straight pipe from turbo back ( no cat, no res, nothing) a twin exhaust system would be off the turbo splitting into 2 pipes and u can put a cat, center muffler on them. or u can just put a nice muffler with twin tips on the back...
this is bit confusing for everyone lol
who realy cares, all I wanted was ideas on res or centre mufflers ppl have used, I don't no why everyones botherd crapn on bout what a straight pipe is, who cares realy..
Edited by R32_Damo
Hey Damo, I've seen a few rb'd 240sx's getting around with cherry bomb turbo mufflers, single in twin out with straight pipes... They sound quite unique, I like them.
http://www.cherrybomb.com/products/
Either that or have a look at some of the XR6 exhuaust products... there are some great 4" high flow/low sound-drone center mufflers out there.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
