I assume by "it wont unlock either" you mean that it is locked right now...
that would be why it doesn't open, so the question is why is the door stuck locked?
Have you tried both using a key and the latch on the inside of the door?
either way, you may have to attempt to take off the door trim and have a look at the locking mechanism, something may be caught in there or it may have rusted/ jammed for some other reason.
but i would say have a look and go from there.
(edit for spelling)
Edited by tiberis
sure is locked now have tried key and inside latch but no go.
but using the key and the latch it will only unlock the the latch (part you can see on the door trim) halfway.
any help on how to get the interior door trim off with breaking it with the door closed ??
also has anyone else had this happen to them ? how did you fix it ?
i dont think u can take off the trim while the door is closed? coz the three screws to remove the door trim are between the bottom of the interior and the door. but not 100% sure...
i also had this problem with mine but i put a little force and shook the key while turnin and it opened. but i dont think its the same prob as urs
Yeah i know about the three little screws down the bottom.
Any more help would be great.
Havent done much execpt pry the door trim away at the top enough to see in.
It doesnt seem to unlock properly by the looks of it so what do i do ?
how bout you remove the thing that surrounds the door opener inside? once its out you might have a little small space too put ur finger and do something lol
you just have to remove a screw i think in the middle and then unclip the surround carefully
  • 4 weeks later...
were you able to get the door trim off at all?
was thinking that you may be able to do it if you take out the front seat. would be a lot of effort, but i think it's coming to the point of trying all options. taking the seat out should let you get to the screws at the bottom, and you mentioned before that you were able to get the top part unhooked. just don't forget the couple of screws through the centre of the door in the arm rest thing.
worst case, you may need to damage your door trim to get it off.. but a door trim costs less than a door if it comes to it.
This happened to mine not 3 days ago. Although I could open my door so no probs.
Start by pulling out the door handle/lock surround on the inside. No screws, just a few little clips. This will allow you to grab the steel rod with a pair of pliers/vice grips and will give you more pulling power without the risk of breaking the plastic lock switch or door handle.
Mine was simply a small piece of plastic jammed into place preventing the mechanism from opening. Don't know where it came from but I removed it and all was well so f@#k it.
Anyways try to unlock and open the door this way first. If it is just something jammed in place, the extra force may budge it just enough, as the plastic handles will not allow as much force to be applied.
FORCE: Sometimes it's the only way. Other times it just seems like a good idea at the time, and can be fun when frustrated.
I'M trying to think without going and looking but cant you wind the window down and use a coat hanger or something to get at the lock mecanism?
Or If the inside lock tab thingy is only opening halfway then something is obviously blocking it, i would try to open and close the inside lock tab fast and slow and hit the door firmly but not to hard to see if it unlocks.
Worth a try. :kiss:
still no go and yes i have got the door trim off had no choice but to break it off tho i still can not get the door open :D tho at this point its the least of my worries now as my motor blew 5 days ago :( but i would still like to get it open any more help would be greatly appreciated
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
