Why not?
Believe it or not the entire Nissan brand is not devoted to under 25's.
Personally i think its a brilliant move and actually like it. Die hard Skyline lovers will buy it.
what better car to buy when you need a second car for the Mrs, want to head down the coast for a holiday with the kids?
Why not?
The skyline "brand" has been focused on performance/sports cars in the past. Lesser so in the past few years, but the V's are still a luxury sports car or whatever category they fit in.
But the crossfire is a totally different category so I don't think it should be branded a Skyline. Surely they can think of a differnent name?
I'm a die hard skyline lover and wouldn't buy it. I have nothing against it, and think it looks ok, but just not my thing.
Fair enough,
But it does have the same 3.7 engine as the Skyline 370Gt and also the same interior.
With that engine you could easily say its a performance crossover :D.
But i do see your point.
Its listed on the SEVS list, but not confirmed as eligable at this stage. They're selling fro around 3.5m yen at dealers in Japan, so for something that would more than likely walk all over all its competition in pretty much most areas, I think its a bargain.
Just thought I would see if there is anyone out there looking to bring in the Skyline Crossover??
Cheers,
Mark
G'day Mark,
I'm interested but at this stage would not want to be a test car (wait 12 month).
Are you actually proposing anything? :)
Cheers
Evgeny
... I think its a bargain.
I did test drive of x1 the other day, reasonable performance model with all 'essential' features would set you back around $80-90K.. It still would not be nowhere near Crossover in terms of performance.. Interior feels cheaper in BMW as well.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
