Item: R34 GTR Rims 18x9 +30 Offset 5x114.3
Car: Any
Condition: Fair
Description: Few scuffs and gutter bashes. Would make perfect candidate for re-spraying or powdercoating etc. Tyres are Nexen 234/40/18 however 2 of them would need to be changed. Other 2 has about 60% thread left.
Price: $1500
Item: Nismo Clear Front & Side Indicators
Car: BNR34 & ER34
Condition: Excellent
Description: Comes with all working bulbs. [NOTE: THESE ARE THE CLEAR ONES, NOT THE SMOKED]
Price: $150
Item: Standard BNR34 180km/h Cluster
Car: BNR34
Description: No marks or scratches at all. Has approx 48,000kms. Standard fascia has been changed over.
Price: $100
Item: Nismo 300km/h Cluster
Car: ER34 Manual
Description: No marks or scratches at all. Illuminates Red when lights are turned on. Approx 110,000kms.
Price: $300 plus swap over for your standard one
Item: DBA XS 4000 Series (FRONTS ONLY)
Car: R34 GT-T
Condition: BRAND NEW
Description: CROSS DRILLED & SLOTTED ROTORS. Brand new in box with all authentications and features the Kangaroo Paw Design.
Price: $450
Item: Standard ER34 Floor Mats
Car: ER34 & BNR34
Condition: Good
Description: No stains at all. Has small cube of padding missing from the drivers side mat due to heel of shoes, but barely noticeable during drive.
Price: $100
All items are located in Castle Hill, NSW. Items can be posted anywhere in Australia at buyers expense. If there are any questions please don't hesitate to ask.
Cheers,
Garland
SAM_4132.jpg SAM_4133.jpg SAM_4135.jpg SAM_4136.jpg SAM_4138.jpg SAM_4134.jpg SAM_4137.jpg SAM_4144.jpg SAM_4143.jpg SAM_4142.jpg DSC03103.jpg SAM_4140.jpg
https://www.sau.com.au/forums/topic/319310-bnr34-er34-parts/
I will take the Nismo clear front and side indicators please. PM Sent
I'll take the side indicators if this fails. I saw its got BCNR33 on the box. Can you please confirm? I'm using it for my 33gtr. Thanks.
hay buddy
ill take the rims if u can hold them until the week end for me (as in this saturday 8th of may)
and if u can find out the price of them delivered to melbourne or if u want me to organise a courier just tell me ur post code
Edited by GUN_METAL_GTR32
Thanks GMan for the Nismo indicator lights, items were as described, prompt communication and fast postage.
Pleasure doing business with you!
Thanks lowbro!
GTR wheels have been sold.
  • 1 month later...
  • 1 month later...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
