Hi guys
thought it was time to put the build up in a post. I brought this shell back in 2007 as a stripped out half roller no rear end with the thoughts of building an all out track car.
As it turns out after a few beers and researching numbers and just a weird feeling about this car and turns out to be a Nismo shell #32 that has been painted in japan bayside blue.
Since I found that out I decided to put it back to orginal condition with some power up mods etc.
The engine is stripped and parts have been ordered they are:
wiseco 86.5mm pistons
eagle forged rods
cometic gasket kit
kelford cams 272 duration 10.2mm lift
tomei cam gears
gates timing belt
DMD Tuning spec forged oil pump
DMD oil head drain
DMD baffled large capacity sump
DMD spec custom head port and polish
Surpertech stainless 1mm oversize valves
Surpertech double valve springs
Supertech titanium valve spring retainers
Supertech valve guides
Supertech buckets
Nismo 14411-06U00 orginal rebuilt turbo's
Nistune ecu tuned by DMD
Standard airbox with custom DMD ram air induction into stock airbox
R34 GTR intercooler (but will prob need an upgrade to 100mm)
Jim Berry Clutch
DMD modified standard AFM's or DMD's MAP to MAF convertor
Standard block as per Nismo orginal spec but cyro treated for stength
Arp bolt kit
JJR cooler pipt kit
JJR dump and front pipe
Apexi N1 exhaust cat back
Oil cooler yet to be decided
The car will be painted back to the orginal gun metal grey with the orginal N1 spec body kit.
Rims will be a month by month choice of either R32 GTR, custom bronze R33 GTR as what was on my R32 GTS4 or work XD9's 18x10 + 15 with the fatest rubber that will fit them.
Interior will remain pretty much bog stock apart from the flip out DVD touch screen head unit which will be showing our custom data logging info with every engine parameter hooked through the car pc.
Brand new standard gtr shocks will take duties of street and drag strip with a set of coilovers yet to be decided for track work. Super pro camber bushes for the front Noltec subframe bushes in the rear with standard rear bushes for the time being. DMD custom hicas lock bar setup and hub mod to be similar to group A spec setup.
Chrome Molly cams spec bolt in half cage will get bent up and installed with bare minimum bars for street and cross bars for the track.
Standard GTR brakes with upgraded pad DBA 4000 rotors cusco cylinder stopper martini high temp brake fluid and no abs as per nismo spec.
Larger rotor upgrade may happen for track work.
That's about all I can think of for the min I have got more pics somewhere of the car when I got it but here is a small taste of the car rolling and the engine in a million pieces on the bench dont mind the mess had to stack all the old parts up as lack of room for other work.
We have got the engine bay all painted and ready for the engine when it's built but haven't taken any pictures yet.
  • Replies 54
Hey mate
yeah the tomei buckets are nice and are actually a better price out of japan then what I can get out of the US.
The oil pump will be a forged set of N1 gears that I get CNC made up. I have a few contacts in the engineering world that do reverse engineering and they did it for a set of stock N1 gears. Will have new oil pressure relief sping set slightly higher.
Basically it will be very similar to the Nitto oil pump.
Also I think I forgot our own cylinder head drain I turned up on the lathe.
David
Hey Russ
how's things?? How's the old 32 going still hitting the track hard with it??
The specs can get very hazy on the Nismo edition but think of it as basically a N1 without the N1 block and in gun metal grey.
If you look at this link on wiki it tells you a lot.
http://en.wikipedia.org/wiki/R32_gtr
cool build man, gonna watch thsi progress
heres the quote from wiki on the nismo edition
"The Skyline GT-R 'Nismo', introduced in February 22, 1990, has a total production of 560 units as required for the "Evolution" models regulation (over 500). Its purpose is to homologate a number of aerodynamic changes used in Group A racing. Changes include additional ducts in the front bumper to improve airflow to the intercooler, a bonnet lip spoiler to direct more air into the engine bay, and an additional boot lip spoiler to provide more downforce. The 'Nismo' GT-R was only available in Gunmetal Grey."
Thanks mate
keep a close eye on it.
Ordered the cams today should be here Thursday
That's pretty much what they are got steel wheel turbos optional a/c no abs and rear wiper plus all the areo mods.
Few more pics guys.
Forgot to add fuel system. Will ne Nismo 555cc injectors I picked these up a few years back for my GTS4. Nismo FPR standard fuel rail Bosch 023 700hp intake fuel pump. Very simple but effective. As some might know gibbson motorsport gtr's used these injectors with a standard rail but different pump setup and made a lazy 580hp with the same turbo's
Started the cylinder head drain last night still deciding what fitting size to use I'm leaning to dash 8 as it is smaller than what others using dash 10 but won't have the same drain capacity but will clear the firewall better
  • 3 weeks later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
