so i should be like "OMG WTF IS MY CAR DOING" -jumps out of car- ???
no you should be like "that is a normal feeling of what abs does when you dump on the brakes on a loose surface and it is stopping the wheels from locking up".
jump in any car with abs and drive along on grass or dirt and jump on the brakes and it will do the same thing.
https://www.sau.com.au/forums/topic/319539-r32-4dr/#findComment-5220487
which on gravel isn't always a good thing, at slow speed on some lose surfaces its a quicker stop to lock the wheels and dig in instead of trying to keep perfect traction. my r34 applies the abs on the rough grassy crap downhill outside my house and it scarily doesnt stop! but thats the tradeoff for not hitting that truck or not skidding out under brakes in the rain
https://www.sau.com.au/forums/topic/319539-r32-4dr/#findComment-5229792
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
