Sometimes you have to wonder what these so called professionals are doing when building these engines when a backyard builder with no certification can build an engine that puts out 350+kw at the wheels, has done 2 years and 24,000kms so far.....touch wood.
Good luck and I hope you will have the beast sorted out!
there's been a few other issues that occurred during the build which have now made me lose all confidence in his workmanship.
1. When he installed the oil pump, he fitted the wrong gasket, causing it to leak instantly on start up, to his credit he did fix this
2. The extended sump which he welded himself had started leaking within a week (he didn't fix)
3. Now this knock..
Three strikes your out I believe?
So why did you get the engine built by someone that has no experience with the RB26?
Often the cheapest build will reward you with an expensive lesson.
The RB26 is a simple engine, and being 20 something years old and internally simple, there are no secrets to making one work.
You should have paid a bit extra and gone to an engine builder that has produced some quick and durable RBs with runs on the board :thumbsup:
Couldnt agree more, I should have gone to an RB expert, however it wasn't a decision based on pricing. I had received a number of quotes, all within the same vicinity.
I truly believed that this person knew what they were doing, he has produced loads of motors with great success
  • 5 months later...
im bringing sexy back! YEAH!
book tow truck... Check!
book workshop... Check!
call Paul... Check!
after 5 months, its time to take the dust off and get it running again.
All the enthusiasm's back! :D
call Paul... Check!
Good.
Now hurry the fark up and get her rebuilt :P
your gonna love pauls work! hes such a champ! he STILL contacting me to see how im going and what im doing next. also hooking me up an external oil pump :P
yeh, you can tell he loves doing what he does
each time I speak with him, it ends up in a half hour plus convo haha
paul (swiper the fox) is building my monster (800-1000hp 2.8) his expertise and knowledge of rb's, mostly rb26s is 2nd to none...
id take this offer up in a flash.... with fuel pump, power fc and injectors u wil b good for 350 to 400kw all day with those -5's
p.s tommo's engine builder n tuner r totally unrelated for those who dont know
Can't wait to see it done Jake. Gotta finally give that diff we imported a thrashing :)
I'd definitely be begging Swiper to build my donk if I had a GT-R. The proof is in the pudding :) The offer is a moving one, even for someone not directly involved. Well done Swiper :)
thommo,
i used newcastle freight forwarding as they have a depot right next to pauls workshop.
i have a tray tilt on my end and a normal on there end (as they have a fork lift) and it was about 200-300.
was 3day turnaround.
http://www.newcastlefreight.com.au/
also if u need a box to put it in i have his one he used to send my engine to me!
so u can have that!?
thommo,
cheers for that.. if you could please pm your contact details and i'll swing past within the next few days and take it off your hands
send the box back where it came from!
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
