Donnon is in the same boat, and last I heard he is becoming a sponsor. We have been lenient up til now, but it is unfair for other legit sponsors who support and make the SAU site possible.
There isnt a sponsor on this site that develops and engineers parts for the R35 that we know of - Resellers yes, but that is all - not that its a bad thing
Our solution was a simple one when asked by the mods - stop posting about we do, and we did - problem solved. 99% of our business is overseas, so there is no point rocking the boat and making waves, hence we dont talk about anything we do here and everyone is happy. Anyone chasing 35 technology is already a member of NAGTROC anyway, and many SAU existing sponsors onsell our technology. Not really the same thing then is it as the poor chap that apparently needs this site to survive :P
I have been a member of SAU since 2002 and our sponsorhip of SAU SA is only for warm fuzzies because we like to foster the community some. We do no - very little - business out of it. Its just goodwill, no more, as is my membership here :P
My boat is there to be sunk then if it makes anyone feel good. Make me Martyr rather than Martin. Its all the same when I wake up in the morning and life goes on regardless :)
^^ since getting to know you more Martin i recommend your business when i can,
i think its a fear thing people may feel brushed off when they speak to you but they don't realise how busy you really are and you don't want/need to chew the phat with someone asking about pipe dreams
Im interested to see how things go with this, and especially to see what Paul finds in the engine that went wrong. A mate went through this a few months ago, except that he ended up with a piston that parted company from a rod, and a rod that wanted to feel daylight. Total loss of the engine, and the forensic analysis of the damage revealed it was either detonation induced, or simple component material failure. The damage was so bad when it happened at nearly 8000 rpm there wasnt much left to look at. You have been very lucky your motor is salvagable.
My money is on incorrect bearing clearances, due to either machining and poor inspection practices, or the rod big ends that being out of round when torqued to spec (or over torqued rod bolts). Measuring bolt stretch before removal of the bolts and after could be interesting.
if you're ever in adelaide paul more than welcome to hit me up for a room/bed
decent bunch down here, not too much tall poppy syndrome
thommo best of luck with the build; im sure it'll be awesome
My theory is the bearings... ACL race series bearings arent the greates... their not too bad, but up againt genuine nissan bearings, its chalk and cheese.... excellent reading though... great to hear things are getting sorted
most of the busted stuff we get sent to fix up is due to poor assembly practices. Component failure is quite rare if they are prepared and assembled correctly. It appears to us that new parts are being fitted to an engine block thats been ill prepared without so much as discarding the packaging. Quite often the root cause of these failures is still buried somewhere in the build and has not been assesed and rectified
some food for thought...we have built several "insert big jap brand" RB stroker engines that we insist be correctly prepared before use. The certain brand im refering to costs about $1500+ to get it to a standard where im totally satisfied that its the best we can offer.
this is the reason up to certain power levels i recommend using STD 26 conrods. Yes they need a few bucks on them to get them serviceable but this cost is about 1/2 of the cheap chinese stuff which we have found need the same treatment anyway. An $800 set of rods can cost double that after you fit decent small end bushes, resize the big ends and get them balanced.
unfortunately these components often get the blame for failure when things go south, when in reality if the builder has enough experience with these engines, good product knowledge and correctly prepares/assembles the parts they often survive quite happily when using the cheaper brands. A well assembled engine using cheaper parts will always outlast a poorly assembled engine using mega buck parts.
Edited by Fair Enough
still waiting for pickup, I was told wednesday afternoon...
called them yesterday " no worries, we'll get it sorted"
called today... "i'll find out whats going on and call you back"
still waiting........... ;)
That actually works well as ive got 3 going between now and monday. That will free up a stand for yours as if i had it now it would be still sitting in the crate. ;)
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
