Hey guys,
About 3 months ago I bought a power fc for my gtst and got it installed and tuned by trent at status.
It made 192kw on 12psi with the stock turbo and usual fmic/pod/exhaust.
On the way home I noticed it the knock warning coming on a few times under full load, so I took it back and he took a bit of timing out.
After that all was sweet.
A few days ago, I took the car to re customs to get a check up and ray replaced the plugs and said all was good.
Problem is now, I'm getting the occasional knock warning again under full load.
On the way to work today; in 3rd full load down the freeway the warning light flashed, I looked at the hand controller and it read 132.
I figured it might have something to do with the AC on, so I turned it off and tried again.
Now more often than not the warning light flashes under full load and reads anywhere from 50-70.
I know this shouldn't be ignored; but I need some advise.
Take more timing out?
Try some split fires or z32 afm?
Ignore it?
I don't think it's pinging, but to be honest I've don't know what I'm listening for.
https://www.sau.com.au/forums/topic/319627-power-fc-knock-warning/
You had the A/C on today in 15 degree weather? :P
It's just a simple case of a cell or two adjusted, just take it back to Trent.
Doesn't surprise me given the cold ass weather we are experiencing that it's hitting map area's now that you wouldn't have 3 months ago...
Nothing major to worry about, just take it easy until the tune is adjusted.
as trent said check your boost control, the hand controller will show you peak boost if you are using the powerfc boost kit
if you arent, you could consider hooking up the map sensor for it to display on the hand controller ($200 map sensor and $20 loom)
I find it best for over boosting is to remove 3 degrees from load rows that aren't in use,
for example:
row 15, reads 16, 16, 16, 17, 17, 18
row 16, reads 13, 13, 13, 14, 14, 14
row 17, reads 11, 11, 11, 12, 12, 12
You get the idea
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
