hey guys i just changed the inlet and outlet gaskets on the turbo as it was making no boost when i bought it, and now that the exhaust leak is gone it sounds normal and makes boost, but cuts out when it hits around 12-14psi. the car is completely stock, and i mean literally completely stock. first off, how come it makes 14psi. And secondly, is there a built in fuel cut etc that kicks in around 1bar? need to get it on the road asap as my other cars have a few issues lol. thanks in advance guys.
https://www.sau.com.au/forums/topic/319634-rb20det-boost-cut/
yes there is a built in cut in the ecu.
as for the pressure it is running, check to make sure there is no boost controller in the hose from the intercooler piping to the wastegate actuator. if there isn't then when you replaced the gaskets you may have reinstalled things so that the wastegate flap is fouling on something and not working properly.
Pretty certain RB20DET doesn't have a fuel cut. Only limiters built into the R32 GTSt is a rev limiter (around 7500), and a speed limiter (180kph).
So, how many revs are you pulling when you have 12psi and the "limiter" cuts in?
It could be running high boost for a number of reasons, like a leak in the wastegate actuator hose, or the wastegate isn't opening correctly.
the wastegate vacuum hose has a manual valve t'd into it, so i removed it today and it now hits around 12psi again but the engine doesn't cut out. it still acts a little strange sometimes when its on 12psi i.e hesitation etc. but overall seems to be running better. and no fun police now lol. looks like its making 12psi at around 3000-3500. couldn't really watch but it build really quickly.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
