hey guys
latly iv been noticing my gtr is dropping oil pressure on hard accelration
mainly first an second gear drops to bout 2 bar and have seen my preset warning light come on at 1 bar
only for bout a micro sec, asson as i change gears pressures back up
normal driving not probs what so ever or even building boost slowly
motor has just under 6000kms on it and dosnt make any wierd knocks
motor feels strong with no lose of power (332kws)
usally iv got 2.8bar of oil pressure at idle
and bout 5-6bar a 3000rpm
im running an
apexi oil pressure guage
tomei oil pump
tomei sump baffle
head restrictor
motul chrono 300v oil over filling stock sump with an extra litre
is this the common rb26 problem that i keep reading bout??
im just abit worried
thx guys
https://www.sau.com.au/forums/topic/319797-rb26-oil-pressure-drop/
  • Replies 53
How many litres do you put in the sump?
I put 6l in every oil change with a stock sump. I have seen this happen before, even 3rd gear full acceleration.
Even with the tomei baffle it happens, I'm suprised.
I'm seriously looking at a sump extension to help fix that problem, and a head to sump breather pipe.
6 litres in the sump on change,
im changing the oil on tuesday as its burnt a tiny bit of oil
it was the first time running full synthetic oil after run in
but on the tomei oil pump i left the oil pressure on the lowest setting (ie. didnt add any extra shims)
but where does 6 litres, or the extra litre get you on you on the dip stick? depends on oil cooler setup etc.
it should be on the bottom of the hump on the stick above the H mark.
i too have the tomei baffle but saw oil pressure drop on hard accel with the dipstick on H.
filled it up to the hump above H and no more pressure drop.
hmm, I personally would not be running a tomei pump without an extended sump. check the flow rates for the tomei pump and you will see it can empty the sump pretty quickly... JUN Tomei etc all strongly advise against running their pumps without increased sump capacity.
  • 2 years later...
Hi Guys
As part of my current build I will also be running a Tomei oil pump, ACL bearings (with an extra thou clearance) and sump extension (8L capacity). Unsure of oil weight as yet...
I am interested to know what oil pressure you're reading at say idle, 3k, 6k and 7.5k RPM?
Also those who doing track work what pressure drops are getting down to?
Reason I ask is am trying to figure out with EPC valve to run with Accusump....I found this doc from Canton, see link below:
http://cdn.racerpartswholesale.com/downloads/EPC%20FAQ.pdf
But just want to confirm the 35-40 psi valve is going to be the correct one??
Really unsure at which level of oil pressure (psi) I want the Accusump to open...35-40 psi Or 55-60 psi??
Cheers
i have 100psi at 7500rpm. nitto oil pump and running 20w50 torco sr1 oil.
Thanks mate. Appreciate that. Do you get any oil surge/drops in pressure?
Would be great to hear from others actually using an accusump and what EPC valve you're running...
Cheers
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
