Hey guys,
FML Story: Last night I was leaving Crown with a couple of mates and as I'm reversing out of my spot one of my mates in the back asked me a question. I look in the mirror and answer him and clip one of those concrete pole things..Don't know how so much damage could have been caused by going like 2km/h..
Sucks when my first accident ever is something so stupid that could have been avoided by paying more attention...only myself to blame.
Anyways, now I need just a stock R33 front bar, drivers side front panel and a drivers side headlight so if anyone is wrecking an r33 or has these parts for sale please pm me. I'm in the Eastern suburbs.
Also, some good panel beater recommendations would be handy. I have done a search on this and found a lot of recommendations for DT Panels so i'll probably hit them up.
Cheers guys.
https://www.sau.com.au/forums/topic/319869-stacked-the-33/
"Sucks when my first accident ever is something so stupid that could have been avoided by paying more attention...only myself to blame."
At least its out off the way now! No longer a virgin....look on the bright side...its minor and fixable, no one got hurt and the first accident jinx is gone!
Dr Drft...
https://www.sau.com.au/forums/topic/319869-stacked-the-33/#findComment-5223163
hey chris, did the headlight actually come out and smash? or is it just some bracket broken that holds it?, as others said you should be able to find the parts pretty easy and get Vu to spray em and fit em, if need be.
look on the bright side, your front bar was needing a respray anyway.
https://www.sau.com.au/forums/topic/319869-stacked-the-33/#findComment-5225759
Yeah just the plastic bracket thing broke. I'm not taking it to Vu, he didn't reply to my email yesterday and I wanted it fixed asap so I took it to a place near my house with a decent name. Should be getting it back on Friday...
And yes, it did need a respray so should look good at the end of it all
https://www.sau.com.au/forums/topic/319869-stacked-the-33/#findComment-5226330
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
