is the genuine nissan 7.5w30 engine oil any good? i just changed my oil for this stuff on the weekend...but i have no idea how to tell if its doing the engine good! It's only $29.95 for 5L so if this stuff is alright then I'm going to be using it from now on :P
cheers
greg
https://www.sau.com.au/forums/topic/31995-genuine-nissan-75w30-engine-oil/
  • Replies 59
Its what nissan say u should use.
Nissan also say your car only outputs 185-206kw too. And they say the drain interval is 10000km :)
I wouldn't use it unless my car were stock. As it is, I pay more for some better stuff and change it twice as often.
Nissan also say your car only outputs 185-206kw too. And they say the drain interval is 10000km :rofl:
for the RB25DE the recommended drain interval is 15,000 km :bs!: i change it every 5,000 km, of course. on the bottle is says to change oil in turbo engines every 5000km. the only mods i have done are full exhaust system and pod filter so internally there would be no more stress on the engine than a stock one (i think?!). anyway thanks for all the replies :O
the mechanic who did my major service put in penzoil synth 15-40 in my car. my suggestion is not to use that oil as at mid rpms, say 3500+ on the highway, the pressure is real low. it seem that at that amount of constant revs (hume hwy) the oil either broke down/foamed badly or was to thick to drain down through the motor at speed the pump was putting it back at the top.
i'm about to head up the gold coast & i'll be changing back to helix 0-40 as the oil pressure was much more constant and stayed higher on the gauge
  • 1 month later...
I recently changed the oil in my r33 GTST to Penzoil Synthetic 15 - 30.
I don't know what sort of oil was in there before but the 15 30w hangs around the 2 mark on the pressure guage at idle and rarely above 4 on freeway driving. The previous oil would idle round 4 and be around the 5 - 6 mark at 3000rpm. Some people have told me its bad to have low oil pressure but can't tell my why other than the obvious NO OIL!!
cyphen, the oil pressures you mention sound about right. oil pressure of 2-3 once warmed up is perfectly healthy and normal. when warm mine idles at about 1
Greg, what oil do you use? On mine idle is a little bit less than 2, and between 2-4 when cruising, and up to 4-5 when accelerating. Maybe can even reach 6 on very hard launch.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
