Hey guys
More details to follow but i'm trying to organise a cruise for the 26th June
Meeting place is going to be Kmart car park (nearer to autobarn tho)
Destination: Sideling (why not, they have also redone some corners for targa too)
Anything is welcome - boostcruising members will also be coming so hopefully we get a decent amount of ppl showing up (do not attend if this bothers you)
so who wants to come?
https://www.sau.com.au/forums/topic/320000-lonnie-area-cruise/
  • Replies 59
someone on boost brought up that the sideling gets no sun in winter and they had a cruise through there in winter before and some ppl struggled staying on the road
so we might try and avoid that
looking like just cruising up the west tamar, over the batman bridge, chill there for a bit and come down the east tamar
also going to have a mini-meet soon to discuss the route further, probably this weekend in town somewhere
if everyone drives sensibly and obeys the road rules, there wont be any drama on the sideling, if people insist on driving like hero's then there will be issues wherever the cruise is held.
and considering what happened recently in nsw after an sau cruise, i think it would be appropriate to keep it tame.
sav man i agree about the cradle route, lots of good driving up there aswell, might be too far for some though..
Edited by BXAFTW
thanks for the input guys
if we try and have a small meet soon i'll bring a map and we can discuss where to go, where has nice roads, where isn't too far and all those things
if we go up and around the tamar (to the batman) its got a couple of corners but its just nice cruising around there
I agree with savman and bxaftw,don;t let a bit of rain or wet roads wreck a cruise.[every one should drive to conditions]
I drive up and down the east and west tamar every week [what a boring drive] :D
He what about frankford road to westbury turn off then to osmaston,golden vally,mole creek,king solomons mines,paradise back to sheffield and the back road to e/town and back to launny any way u like. :)
Or somthing simmilar.
nissangts
Edited by NISSANGTS
nissangts
say what now? can you put that into a google maps thingo and post it up?
i see mole creek in there, and i know targa goes through there, so i trust your planning
post up what the route looks like and the distance and we'll take it from there
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
