Hi, Im Jake, im 19.
Recently i purchased this bad boy.
Its a 1987 Nissan Skyline HR31 GTS-X.
It has 126,000kms on the clock, and im stoked!
Runs a Redtop ECCS Rb20det, with a couple goodies, including a HKS 2510 turbo, GTR Intercooler, Malpassi Fuel Regulator, Fuel Cut Defender, BOV (needs removing), 3" Kakimoto Exhaust, Oil Catch Can, RB25det rocker covers, and a pod filter.
Suspension wise, it's got Pedders lowered springs, Pedders Shocks, and adjustable castor rods.
Rims are a set of 17x9 Stich Meshies for the front, and rears are the same, but in 9.5.
Paint is a custom pearlescent black. Basically, it's a 2009 Hilux black, with silver taken out..and a bit of sparkle/blue is added, looks pretty nice in the sunlight.
Exterior consists of a GTS-R spoiler and a modified GTR front lip.
Interior contains a CD player, Autometer Boost Gauge, and a Personal steering wheel.
Like every kid out there..i want this thing to have a rb26dett, full straight cut gearbox..yada yada yada, but no.
For the time being, im planning to get a NIStune, some decent spark plugs, Yellow Jacket Coilpacks, Coilovers, and a proper tune. Nothing over the top, but something that i can manage to keep me, my bank account, the parents, and the police happy.
https://www.sau.com.au/forums/topic/320108-jakes-hr31-gts-x/
Very nice :) Im running the redtop eccs motor in my oz spec r31 with a r33 sr1 turbo but looking at going hks 25/30 very soon. If your looking at getting your butterflys removed boostworxs will remove them for around $60 if you take the plate in.
Id put a set of redtop rocker covers back on :3some:
Cheers guys,
Didn't know many people still liked 2 door R31's!
Car currently does have some small things that need fixing.. seems to have a small flatspot at 3000rpm, but only in third gear..wether that is spark plugs, coilpacks, or something else, i plan on getting on to it.
Also, has a bit of detonation at 5000rpm. Again, it'll need a proper tune, this is where the NIStune will be coming in handy.
I'll most likely be giving Decs at Garage 7 in Adelaide the reigns of her, he's a good mate, and specialises in R31's, so i have no doubts about his abilities.
Being an apprentice diesel mechanic myself has it's benefits, a pit, quality oils, scanners and trade discounts at my disposal, i plan on making this thing run well..might enter a car show here and there, also, plenty of Track Days! My old automatic r31 loved it last year around Mallala, so this thing should do the same!
Edited by skwiz
This was going to be my daily whilst the R32 went stoopid impractical but still slow spec :) Agree, a neat R31 coupe is a cool daily driver. Wish that prick never tee boned mine all those years ago, I would still have it! Only grabbed my current R32 because it was neat and and i couldnt find another neat R31 back in 99. Fark that was a long time ago :D
whats with the TRD wheel :P
NOT YOU TOO!
Everyone notices it!
I'm not exactly too sure why it's there. Probably going to get my Momo Typ 35 steering wheel re-trimmed, and a momo horn button fitted soon, so it really isn't annoying me.
Also, tonight after work i fit up a new set of spark plugs. NGK Iriduim IX's. The older plugs that were in there (Bosch Platinum's) weren't that bad looking, had the usual burn marks on the tips. The Bosch one's also had quite fat tips underneath the metal barb covering it, whilst these NGK's have almost a pin needle with end to them..can anyone tell me why? It seems to have fixed the flatspot i had also..strange things.
Ordered a NIStune today from Garage 7, and should be installed next Monday afternoon. Fuel cut defender will be taken out, because apparently it is useless, and just tricks the AFM and ECU into doing different things. Tune and Dyno time will be done shortly after.
I'm unsure what power it will make. I'm hoping 16-17psi daily. When i told Decs, that the former owner said it make 217kw on 18psi, all i got was laughter..i too have my doubts about this.
I'd like 180-190kw, on a pretty reliable tune, nothing silly, but enough to keep me occupied.
I'll keep ya posted.
Jake.
Small update.
Got Garage 7 to install the NIStune Type 1 liveboard this evening, tune should hopefully be done within 2 weeks, on a hub pack dyno, mainly for the accuracy of these units. Fuel Cut Defender was removed also.
Will also be doing the Garage 7 AU Falcon Coilpack Conversion.
Cheaper, and something different.
  • 3 weeks later...
Got the car back today from Garage 7, and im extremely happy. Although Decs couldn't get it on the dyno today because of a small issue with another car at the dyno place, it should be done Monday.
I got the AU falcon coilpack setup done, aswell as a Bosch 040 fuel pump.
Decs has been fiddling with the ignition and fuel maps, and explained and showed me on the laptop, what it is doing, which im happy with..any excuse to get to know what my car is doing! There is no hesitation before the turbo hits boost like there was, and it just seems to run alot smoother than it did.
Bring on Monday's dyno time! Im not exactly too sure on what to expect power wise. I've been told 190kw, others 170kw..so i really am not too sure. Guess it depends what the injectors and AFM like.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
