Greetings all,i'm heading down to your lovely isle for a few weeks touring.Been down there a couple of years ago,this time i'm bringing my 33 with me,she is grey green metalic so you can't miss her by her unusual factory colour,allso has a sau sticker on rear qtr window.Hope to catch up with some of you while i'm down there,i'm old but i don't bite. :down: . Genelle. :P
https://www.sau.com.au/forums/topic/320131-coming-to-tasmania/
  • Replies 60
Ooh that looks like heaps of fun,soon as i'm on the spirit of tassie i'll let yous know,oh btw are any of you guys going to biggest dyno day saturday in hobart? I'm going to be at the o2 autosports one in nowra south coast nsw. :(
you'll be glad you brought youre car, this awaits..
enjoy!
thats funny, thats me and some friends standing next to the guy in the bright blue/green pants, that was the best targa stage out of the whole targa. loved it
Post up some dates when you know you're going to be in Launceston-town - then to the pub!
Hey guys,should be in the next couple of weeks,hubby is gonna be working down there for a month,i'm cruising around every where for a month,no worky for me,i'll post up soon as i have dates,i can't wait love it down there. Genelle. :)
hey tom,
its on the west coast near queenstown, on the way to an old town called gormanston. the landscape is really bizzare from all the mining that used to happen in the area, some of the hills are covered in sulphur (i think) as they are orange/pink.
id be keen for a cruise with some of you guys if you ever want to head down there.
a great cruise is, down the the west coast through gormanston and on to hobart for tea then midland highway back home north.. its an all-dayer but so worth it.
Edited by BXAFTW
hey tom,
hmmm, maybe i'll try and organise that for the spring
or the end of uni
mmmm, last exams, west coast drive then to hobart then watch powerfinger :thumbsup:
Have a great time Genelle :ninja:
NSW won't be the same!
All that Macquarie Pass stuff you've done has been good training for Queenstown > Gormanston and even Bass Strait !!!
Cheers Terry,i intend to have a great time cruising down there,got plenty of woollies,getting pretty chilly down there now. Genelle. :banana:
Cheers Terry,i intend to have a great time cruising down there,got plenty of woollies,getting pretty chilly down there now. Genelle. :ninja:
not so much warm cloths needed, more wind proof
saying that, today is amazing - sunny and cloudless will a small breeze just wearing a light jumper
but get up to some altitude and the temps will drop and your car will love you for it
when your down near deloraine or launceston look for a road called lake highway - its high and twisty and very good
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
