-For sale is brand new in box 86.5mm CP piston set for RB26. Compression ratio is standard 8.5:1
Comes with all rings, gudgeon pins, clips and exact setup measurements.
Looking for $1100 ono. Look around you will not buy these in Australia for this price.
RB26 CP pistons
-Full complete RB26 head without rocker covers reshimmed recently
Looking for $1300 ono
-RB26 R32/33 GTR power FC PRO with hand controller. Yes the one with launch control and ignition rev limiter
$1500 (i really don't want to part with it but it is not being used)
R33 GTR fuel pump 60,000km
$150
R32 GTR front diff and sump complete
$300
RB25/26 head external oil drain kit
$120
RB series head drain
Contact Ben on 0401 779 905 for any other questions
Edited by BK
https://www.sau.com.au/forums/topic/320231-rb26-head-r32-gtr-sump-power-fc-pro/
  • 3 weeks later...
Price drop
$1000 for cp pistons
$1100 for head
$120 R33 GTR fuel pump
$250 GTR sump
Power FC pro + Hand controller - make an offer
Sorry about that. Drain kit is sold pending payment. Rest is still available at:
$1100 for head
$250 GTR sump
Power FC pro + Hand controller - make an offer !
Have to offer more than that for me to let go of the Power FC Pro. They are not very common. Also everyone asking if the Pro unit is d jetro/MAP sensor based the answer is no. You need to run Airflow meters. Following still for sale :
$1000 86.5mm cp pistons + rings - FIRM PRICE
$1200 OS giken R3C triple plate
$250 GTR sump
$1300 Power FC pro + Hand controller
Edited by BK
  • 3 weeks later...
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
